2016-10-01 |
202.75 |
5.44 |
$0.904 |
37.27 |
"70% city, 30% highway. Short fill but first with me driving. Wanted an idea of mileage. No Scanguage or mods till just before fill.
Purchased Aug. 17, 2016. Initial fill at 309,315km." |
2016-11-01 |
422.22 |
10.51 |
$0.24 |
40.17 |
"All city driving except for a few short test runs on the highway (Maybe 20 km total) , trip distances 1-5 miles (2-8 km). Avg speed 30 kph, mostly rush hour stop and go traffic. temp range -5* - 5*C (20-40*F)." |
2016-11-24 |
257.5 |
6.66 |
$0.834 |
38.66 |
"94% city, 6% highway. Temp range -10*c/ +15* c. Some Snow and slush, winter tires on. Most driving in the dark, need lights and heat for defroster. Major road construction traffic jams. Trying to work on P&G technique in heavy traffic." |
2016-12-30 |
321.87 |
9.38 |
$0.688 |
34.31 |
"All city driving, short trips, 4-5 miles or less. Several weeks of -20'sC with wind chills in -30'sC. Temp range 0 to -29C. Some snow covered roads and mostly driving in the dark. Replaced the MAF sensor near the end of this tank." |
2017-01-27 |
283.47 |
7.69 |
$0.994 |
36.86 |
"All short trips in city. Avg. speed 30kph on scanguage. first two weeks -20's to -15C then warmer (-15 - 0C) Replaced lower control arms about the time it warmed up. Car coasts much better after. Not sure if it was the cold, control arms or both. Jury still out on new MAF sensor. Seems like it was getting better mileage with faulty sensor, monitoring closely." |
2017-03-08 |
427.5 |
10.62 |
$0.974 |
40.25 |
"97%city 3%highway. Avg. speed for tank 31kph. Temps all over -25c to 10c and a few snow days. About half the tank really cold. Installed kill switch and DRL delete switch about halfway through tank. Trying more EOC when the weather cooperates.
Best commute: 4.2 l/100km - 6.5 km." |
2017-05-01 |
458.88 |
10.67 |
$0.964 |
43.01 |
"All city, short trips. About a third was with passengers, doing weekend errands with the family. Temp range -10 to 12 C. Really erratic weather. avg. speed for tank, 30 kph. P&G EOC when possible, or EonC. Also timing lights and DWL.
313,136km" |
2017-07-08 |
528.17 |
10.33 |
$0.236 |
51.13 |
"95% city/ 5% highway. Avg. speed for tank 30 kph. First tank this year all above freezing temps. Mileage adjusted based on GPS short trips. Changed my route to a longer route home with fewer stops due to road construction. Think I will stick with it. Doesn't work for the trip to work though." |
2017-08-29 |
432.16 |
8.16 |
$0.954 |
52.96 |
"80%city / 20%highway. temps between 10-28*c. Avg. speed 34 kph. Changed SG offset to 12%, under-reporting.
314,648 odo Tried P&G on highway with fully loaded car. may have thrown off SG. Mileage adjusted based off of GPS." |
2017-10-13 |
315.66 |
6.31 |
$0.2406 |
50.03 |
"90% city/ 10% highway. Temp range for tank is -5*c to 25*c. Did another short fill this time. I'm hoping I got the last of the summer gas. Also, updated the Scangauge and wanted to start with a fresh tank. Fuel offset still at 12% but set engine size up to 1.7L. SG still under reporting for some reason. Will see if this helps." |
2017-11-01 |
211.08 |
4.39 |
$1.139 |
48.08 |
"95% city driving. Temp range -9*C to 15*C. Winter tires just on, Scangauge still way off. Reset offset to 20%. Short fill again as gas is skyrocketing. full grill block on now. Installed fan warning light last week." |
2017-12-30 |
645.36 |
14.6 |
$0.79 |
44.2 |
"All City. Temps. 15*C to -30*C and -40*windchills. Mostly driving in dark in Dec. Lights and a little heat. Some snow but overall milder weather than last year. EOC when possible but less than in summer. Family car usage about half time." |
2018-02-12 |
430.92 |
9.52 |
$0.959 |
45.26 |
"Price includes points discount.
95% city; 5% highway. temp range 0*C to -35*C. Wind chills to -48*C Really cold for the last month, mostly below -10*C. Avg. speed 30 kph. Filled a little early because engine bogging/stalling. Thought it might be a fuel issue.
Lots of EOC this tank even with the cold weather. Back up battery is helping keep battery up." |
2018-04-05 |
411.66 |
8.51 |
$1.149 |
48.37 |
"All city, avg speed 30 kph. Winter weather. Temp range 6 to -35*C. Avg. temp -12*C. About 30 - 40% driving with passengers. Lots of EOC." |
2018-04-07 |
219.78 |
5.05 |
$1.139 |
43.52 |
"98% highway. 15 mph SE wind. Tail/cross wind first half, head/cross wind second half. Speed 90 - 110 kph. temp. 12-15*F (-12/-9*C) Not hypermiling as hard as normal. A little EOC but mostly just DWL.
Last entry, lent to my son for a while then sold it." |
