Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 12-01-2015, 07:43 PM   #1 (permalink)
Adding acetone to gasoline
Well, I found a good spot to ask. Seems everyone has their own experience and opinion on this..
Does adding ACETONE, (some say Toluene and some say Xylene, all available at Home Depot, Acetone at Walmart in nail section, 100% pure) DO ANYTHING? GOOD OR BAD? *to pump gasoline
Unrelated, but I found that laquer thinner in gas does NOT clean a catalytic converter, but does make whole car run better, if done in one nice, long, hot shot. Scott Kilmer is wrong. I didn't destroy the car, either. And I used a strong concentration..
Old 12-01-2015, 07:48 PM   #2 (permalink)
Cd
Ultimate Fail
Cd's Avatar
https://www.google.com/webhp?sourcei...ne%20ecomodder
http://ecomodder.com/forum/showthrea...etone-228.html
The Following User Says Thank You to Cd For This Useful Post:
mcrews (12-04-2015)
Old 12-01-2015, 07:56 PM   #3 (permalink)
Cd
Ultimate Fail
Cd's Avatar
I'm thinking of adding urea to my gasoline.
mcrews (12-04-2015)
Old 12-01-2015, 08:59 PM   #4 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 39.03 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
I'm running paint waste solvent in my car as we speak. It contains Acetone, Toluene and Xylene and a few more solvents. If any thing I have seen a increase in fuel consumption. It does help with knock at WOT high load.
The engine runs the same as if it would on pump. Depending on the batch I will adjust the fuel and timing tables to keep my A/F ratios the same as pump.
Pressure Gradient Force
The Positive Side of the Number Line
Old 12-02-2015, 04:15 AM   #5 (permalink)
Send a message via MSN to markweatherill
Automotive homeopathic remedy?
An occasional few 100ml dose of acetone is a good engine cleaner. I did try regularly adding small amounts to no noticeable effect.
Old 12-04-2015, 09:33 AM   #6 (permalink)
I have done it in the past, and had seen mild MPG improvements. Supposedly it helps to clean valves and combustion cameras from built up. But that was on carb'ed motorcycle.
I think it may destroy catalytic converter and is not compatible with rubber fuel lines, so it may be not much harm to use it in small quantities as a cleaner, but long term would not recommend, YMMV
Old 12-06-2015, 12:27 AM   #7 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Why acetone in gasoline doesn't work to improve fuel mileage.
1) it has lower energy content than gasoline per volume.
2) it lowers the octane rating (it used to be used as a winter time diesel fuel additive to aid in starting).
3) it can eat fuel lines and plastic parts thus causing leaks.
The Following 3 Users Say Thank You to ConnClark For This Useful Post:
gone-ot (12-07-2015), kwijibo (07-24-2017), mcrews (05-21-2016)
Old 12-08-2015, 04:32 PM   #8 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 50.48 mpg (US)
Are you saying you're planning on taking a whiz into the tank?
I only ask because we haven't heard from these guys lately: Cli-Fi.Net (blog): The Urinator: A green hybrid car that runs on urine!
Old 05-18-2016, 08:27 PM   #9 (permalink)
the green machine :P - '97 Jeep Grand Cherokee ZJ
90 day: 20.92 mpg (US)
Thee s10 - '00 Chevy S10
90 day: 24.27 mpg (US)
Freedom - '05 Kawasaki Ninja 250EX
90 day: 75.55 mpg (US)
I personally have used acetone in my Jeep Grand Cherokee, and have gone from 18mpg to 22mpg whenever I use it for a 4mpg improvement(around 18% increase in fuel economy)!!
Old 05-18-2016, 10:22 PM   #10 (permalink)
It's not even April 1.
