03-25-2019, 11:31 PM
Advice on rolling stops or full stops
In the last month or so I have doubled down on my---well its not really hypermiling, because I don't do all the dozens of tips listed at the 100 tips link at the top, but I was able to get 26.1 on an out of town freeway trip, in a new to me 2006 Highlander Hybrid, when the adjusted freeway EPA MPG was 25. So I am doing well in remedial Hypermiling 101.
At any rate, I have noticed in the last month, that I've also been doing a lot more of what I call the California Rolling Stop, instead of a full stop at a sign.
What is the experience & advice of people here? Do you folks do this, or do you come to a full stop, even when there is nobody there? Or do you work on a compromise, like a full stop for a split second, before moving on? I don't know if that would require any less gas, than emerging from a full stop for 3 full seconds, which is how I learned to stop in drivers ed way back when.
03-26-2019, 01:57 AM
Master procastinator
A stop sign is a stop sign. It's there for a reason.
In my opinion, safety goes before saving a drop or two of fuel.
Reason: Corrected typo
03-26-2019, 04:58 AM
I roll when I'm in the middle of nowhere. YMMV
03-26-2019, 07:36 AM
How much does a ticket for running a stop sign cost?
03-26-2019, 07:48 AM
Never got one. I dunno.
03-26-2019, 10:57 AM
Unless your rolling stop is at 15 miles per hour, it's not going to save that much fuel. Do I rolling stop? Perhaps very slightly sometimes but I'm very nearly stopped, and that's more to do with not wanting the full "jerk" of stopping and to save a second, not to save fuel.
If you've got a hybrid it's already recapturing some of that stopping energy.
Failing to obey a traffic control device (stop sign) is a hefty ticket compared to speeding, and is seen as way more serious.
03-26-2019, 11:23 AM
Rat Racer
If my engine's running I'd rather come up from 1 than from zero.
A nearly compliant rolling stop is a good, solid deceleration to the line with an extra push on the brake at the line to give the car more decel and a dip. With the dip it noses down and rocks back. At a low enough speed it looks good and conserves half a smidgen of momentum.
If my engine's off, I bump start as part of coming to a halt, give the engine half a moment to realize it's awake and then move on.
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
03-26-2019, 12:56 PM
Toby - '13 Toyota Prius C 90 day: 61.95 mpg (US) Daz - '15 Mazda 3 iTouring w/ Tech Package 90 day: 38.2 mpg (US)
If I can conserve enough momentum to stay out of 1st gear at intersections without dropping the RPMs below idle, gas is saved. Seems pretty simple.
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
The Following User Says Thank You to mpg_numbers_guy For This Useful Post:
03-26-2019, 05:01 PM
#9 (permalink)
EcoModding flying lizard
I almost always come to a full stop. Only times I skip it are when people are racing up behind me, threatening to rear end me. I'll pull away about 3/4 of a second after stopping. If you stop and wait for 3 seconds people here in Georgia will honk the **** out of you and/or crash into you.
It definitely doesn't help my mileage having to get the 3300 lbs rolling from 0, but it does help in not getting tickets. You never know when a cop may be watching. 0 tickets in 6 years and counting. I have had police threaten to throw me in jail, and falsely accuse me of "stopping traffic and drag racing" when I had a motorcycle break down on a road without a pulloff, but that is a little different...
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
Originally Posted by MetroMPG
You can lead a fashion-conscious horse to unusual-looking water...
03-26-2019, 06:27 PM
#10 (permalink)
Rat Racer
The only time I got tagged was when I sawed through a chicane that had a stop sign at either end. I was only watching out for safety, not watching out for everywhere that had line of sight on me.
That was not hypermiling and nowhere near a rolling stop. It wasn't quite drifting either, but...
