Old 09-20-2010, 12:31 PM   #61 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Great idea!
I have drill bits up to 1". I am just not sure I want holes in the aero covers. Would a 1" hole be big enough? The end on my air compressor is .75".
How much air would excape?
I would think that this much material removed would off balance the wheel. Ideas?
Old 09-20-2010, 01:53 PM   #62 (permalink)
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 18.97 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
I use a bubble balancer so it would be easy to balance them
if you had a small hole in the middle to see the bubble. You could plug the hole with one of those hole plug things (plastic/rubber thing).
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
Old 09-20-2010, 03:36 PM   #63 (permalink)
Wiki Mod
I have never heard of this, can you please explain it?
Thanks
Ben
Old 09-20-2010, 07:28 PM   #64 (permalink)
Team Pontiac
They look like small disc with teeth that go through the hole and
clip on to the edges. They are sometimes used in cars to block holes on trunks and stuff. Hard plastic.
1991 F-250:
Old 09-20-2010, 09:21 PM   #65 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Weather Spotter -
Isaac is talking about stuff like this :
Snap-In Plugs: Finishing Plugs for Sheet Metal Holes - Caps n Plugs
The above could either be plastic or metal.
I see lots of these in black or white plastic at the hardware store :
Go to the specialty fasteners section of the hardware store and look over what they got.
CarloSW2
American Solar Energy Society
The Following User Says Thank You to cfg83 For This Useful Post:
Weather Spotter (09-20-2010)
Old 09-20-2010, 09:29 PM   #66 (permalink)
Wiki Mod
That would make the hole much better pop out to check pressure, pop in for use!
One more thing to get at the store next time!
Old 09-20-2010, 09:50 PM   #67 (permalink)
Team Pontiac
They would be perfect for those who balance at home....like me.
You could also have one for each lug nut......for easy tire rotation.
1991 F-250:
Old 09-20-2010, 10:02 PM   #68 (permalink)
turquoise - '97 Toyota Starlet
90 day: 41.46 mpg (US)
What kind of looks do you guys get driving with pizza pan hub caps?
I'm considering it, but they would definitely be painted black.
Old 09-20-2010, 10:24 PM   #69 (permalink)
Wiki Mod
Most people do not seem to see them. On my car they point out the Kammback or grill block, I have to point out that I also added pizza pans.
I like the silver, most all rims are silver so it looks like your car came with moon disks. Black might not be bad.
A few looks are worth 1-2 MPG to me
Other user gains (4.18% average): Smooth wheel covers - EcoModder
Old 09-20-2010, 11:02 PM   #70 (permalink)
...beats walking...
...in the electronics industry, we call those plastic and metal hole "plugs" by the name: BOO-BOO PLUGS...as in: mistake hole fixers.
Commercial Aero Race Wheel covers (clear acrylic) cfg83 Aerodynamics 8 09-20-2010 11:09 PM
aero caps and wheel balancing lightning Aerodynamics 3 05-01-2009 06:54 PM
check out my taped hub caps! modmonster Aerodynamics 9 01-17-2009 10:45 PM
"Pizza pan" hub caps (2008 Civic)? KJSatz Aerodynamics 2 08-05-2008 12:14 AM
Pruis Pizza Pan Hub Caps.... justpassntime Aerodynamics 1 07-14-2008 09:55 AM
