Old 04-10-2019, 10:08 PM   #171 (permalink)
90 day: 19.36 mpg (US)
Skirts would do more, IMO.
Today’s TTs with slideouts are hideously tall.
That which prevents air from getting underneath from the side is highway-proven now with big trucks. Handling is much better.
Skirts are also “easy” versus modding the body.
Have a look at the structure holding the skirt on one of these trailers (53’ van) sometime.
Old 04-11-2019, 07:29 AM   #172 (permalink)
The Green Hornet - '96 Ford Escort Wagon LX
90 day: 39.26 mpg (US)
The Red Rocket - '96 Geo Metro Base
90 day: 53.07 mpg (US)
Biggest issue with skirting is underside access. There would need to be swingout panels to access dump connection, plus all gate valves (I have three, for example).
Other thing to think about is the bottom of most modern campers is already very smooth except for the axle assemblies themselves. They are sealed front to back with coreplast, and along a few drain assemblies stick down.
Old 04-11-2019, 02:30 PM   #173 (permalink)
[QUOTE=93Cobra#2771;595743]Biggest issue with skirting is underside access. There would need to be swingout panels to access dump connection, plus all gate valves (I have three, for example).
Too high off of ground, which is the salient point. What needs fixing. Tank dumps and drain valves aren’t a hindrance.
Old 04-11-2019, 06:46 PM   #174 (permalink)
[/QUOTE]
Approach, breakover and departure angles?
On 4-6 wheels, one could have an active air/hydraulic suspension with a pendulum controller to make it always seek level. That would work for parking, then you could stance it for freeway travel.
Old 04-11-2019, 07:04 PM   #175 (permalink)
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
these trailers are far higher than needed for those clearances. I often wonder if its just to be higher than the neighbors in cordwood campground.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
Old 04-12-2019, 05:49 AM   #176 (permalink)
Clearance angles are easy enough.
Floors are too high due to slide-out mechanisms.
The best non-aero TT of days past was the HOLIDAY RAMBLER. Use it as comp in all ways to “see” today’s.
Old 04-21-2019, 07:06 PM   #177 (permalink)
Dark Egg - '12 VW Touraeg
Right, my slide out is the whole side including the wheel aera and the slide has it's own floor which is the same height as the rest of the floor. The only way that works is to build the camper completely deck over the wheels with no wheel wells.
On a side note I picked this up for free off a buddy who bought a semi to tow his new massive 5th wheel. This deflector was higher than he wanted and the 5th wheel has it's own pretty aerodynamic front. Now to figure out what to do with it. It's 7.5' wide and 3' tall. Make a boat tail on my existing camper? Use it in my camp kitchen trailer I want to build? Cut it down and make a aero bed cap for a pickup? Cut it down and use it as an air deflecting/rooftop cargo carrier when towing the camper?
The Following 3 Users Say Thank You to Hersbird For This Useful Post:
aerohead (04-24-2019), slime (01-09-2020), slowmover (04-23-2019)
Old 04-21-2019, 09:38 PM   #178 (permalink)
Porch roof.
Old 04-23-2019, 02:37 AM   #179 (permalink)
Nice gift. Off an old FLD?
Front of the trailer. Top leading edge. A vertical turning vane down trailer front.
Fairings rest of way for roof junk.
Section it as required.
For FE, raising the TT height not good, but breaking up that blunt entry great.
Changing the TT to DEXTER Torsion Axles should be priority. That’s a fully independent suspension. Work with the dealer and factory on how low you can go. That axle type fan ordered to get this right. (Plus about one-Dozen parts versus more than 200 with leaf).
Old 04-23-2019, 12:48 PM   #180 (permalink)
Porch roof.
LOL, that probably is what it will be, or a dog house. Actually it would make an great Mors "super shelter" with transparent sheeting in the front and a fire built just outside, inside lined with emergency blankets to reflect heat back inside. Little heavy and awkward to pack in very far.
The guy that gave it to me said he wanted to put it in front of his snowmobiles on their trailer to keep the rocks off them. I bet I could build/modify a snowmobile trailer like that and just make some money as I don't have any snowmobiles.
The Following 2 Users Say Thank You to Hersbird For This Useful Post:
freebeard (04-23-2019), slowmover (10-16-2019)
