01-29-2010, 05:36 PM
#11 (permalink)
Left Lane Ecodriver
Originally Posted by aerohead
Does the UFE have active-suspension? It looks like the "whiskers" would be knocked off on driveway ramps,sidewalk curbs, and parking barriers.
No. It's a concept car, lacking ground clearance, rearward visibility, wipers, bumpers, practical ingress and egress, realistic interior, manufacturability, etc.
It has been recommended elsewhere that DIY wheel strakes be made flexible and expendable.
The Following User Says Thank You to RobertSmalls For This Useful Post:
01-29-2010, 05:41 PM
#12 (permalink)
...beats walking...
...I would recommend they also be retractable, which would mitigate their need to be expendable...just have them retract into the body, against spring pressure, whenever they 'contact' something immovable; their flexibility aspect would thus be greatly enhanced.
The Following User Says Thank You to gone-ot For This Useful Post:
01-29-2010, 08:04 PM
#13 (permalink)
T-100 Road Warrior
Sponge foam could work...it's soft enough to compress on impact but firm enough to divert air.
Git a block of sponge foam and cut it down to the shape you want. You'll probably have to attach it with some adhesive...
The Following User Says Thank You to BamZipPow For This Useful Post:
01-29-2010, 08:11 PM
#14 (permalink)
Pokémoderator
BamZipPow -
Yeah, that's a good idea. I think you would need to paint it so that it doesn't absorb moisture.
CarloSW2
The Following User Says Thank You to cfg83 For This Useful Post:
01-29-2010, 08:15 PM
#15 (permalink)
How about retracting automatically under speeds of 10-15 MPH, and then lowering into position when air pressure on the bow pushes them down at higher speeds. The faster you go the lower they get. After all, if you're hitting dips and driveways faster than 10-15 MPH, you're not an ecomodder anyway.
The Following 2 Users Say Thank You to thatguitarguy For This Useful Post:
01-29-2010, 08:31 PM
#16 (permalink)
Pokémoderator
Old Tele man and thatguitarguy -
The Probe IV concept was retractable based on speed (and also springy, I think). I will post another picture later tonight.
CarloSW2
01-29-2010, 08:38 PM
#17 (permalink)
Ultimate Fail
Phil good to see you again.
I use flexible rubber wall base for my 'whiskers'.
It is pretty inexpensive too.
http://www.lowes.com/ProductDisplay?...1&cmRelshp=sim ( $ 2.48 a section )
The Following 4 Users Say Thank You to Cd For This Useful Post:
01-29-2010, 08:55 PM
#18 (permalink)
ecomonkey
if you use these strakes, would side skirts help,or hurt,
01-29-2010, 09:07 PM
#19 (permalink)
T-100 Road Warrior
Originally Posted by cfg83
BamZipPow -
CarloSW2
Plasti Dip should work then...
01-29-2010, 10:09 PM
#20 (permalink)
ecomonkey
cfg83 is there any more to post from that article? have'nt found it on the web yet, noticed the front strake is flat on the inside edge , great info!
