Old 01-29-2010, 05:36 PM   #11 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
Does the UFE have active-suspension? It looks like the "whiskers" would be knocked off on driveway ramps,sidewalk curbs, and parking barriers.
No. It's a concept car, lacking ground clearance, rearward visibility, wipers, bumpers, practical ingress and egress, realistic interior, manufacturability, etc.
It has been recommended elsewhere that DIY wheel strakes be made flexible and expendable.
The Following User Says Thank You to RobertSmalls For This Useful Post:
aerohead (01-29-2010)
Old 01-29-2010, 05:41 PM   #12 (permalink)
...beats walking...
...I would recommend they also be retractable, which would mitigate their need to be expendable...just have them retract into the body, against spring pressure, whenever they 'contact' something immovable; their flexibility aspect would thus be greatly enhanced.
The Following User Says Thank You to gone-ot For This Useful Post:
Old 01-29-2010, 08:04 PM   #13 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Sponge foam could work...it's soft enough to compress on impact but firm enough to divert air.
Git a block of sponge foam and cut it down to the shape you want. You'll probably have to attach it with some adhesive...
The Following User Says Thank You to BamZipPow For This Useful Post:
aerohead (01-30-2010)
Old 01-29-2010, 08:11 PM   #14 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
BamZipPow -
Yeah, that's a good idea. I think you would need to paint it so that it doesn't absorb moisture.
CarloSW2
American Solar Energy Society
The Following User Says Thank You to cfg83 For This Useful Post:
Old 01-29-2010, 08:15 PM   #15 (permalink)
Maroon Ballon - '98 Chrysler Town & Country LXI
90 day: 26.42 mpg (US)
MaEsTRO - '95 Geo Metro 5spd hatch, 3 cyl
How about retracting automatically under speeds of 10-15 MPH, and then lowering into position when air pressure on the bow pushes them down at higher speeds. The faster you go the lower they get. After all, if you're hitting dips and driveways faster than 10-15 MPH, you're not an ecomodder anyway.
The Following 2 Users Say Thank You to thatguitarguy For This Useful Post:
aerohead (01-30-2010), Piwoslaw (01-30-2010)
Old 01-29-2010, 08:31 PM   #16 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
Old Tele man and thatguitarguy -
The Probe IV concept was retractable based on speed (and also springy, I think). I will post another picture later tonight.
CarloSW2
Old 01-29-2010, 08:38 PM   #17 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Phil good to see you again.
I use flexible rubber wall base for my 'whiskers'.
It is pretty inexpensive too.
http://www.lowes.com/ProductDisplay?...1&cmRelshp=sim ( $ 2.48 a section )
The Following 4 Users Say Thank You to Cd For This Useful Post:
aerohead (01-30-2010), COcyclist (02-01-2010), Piwoslaw (01-30-2010), thatguitarguy (01-29-2010)
Old 01-29-2010, 08:55 PM   #18 (permalink)
ecomonkey
silver clown - '02 toyota echo 2 door base
90 day: 47.16 mpg (US)
white ghost - '05 prius base
90 day: 47.53 mpg (US)
white pearl - '12 toyota prius base
Last 3: 45.69 mpg (US)
if you use these strakes, would side skirts help,or hurt,
Old 01-29-2010, 09:07 PM   #19 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Smile
Originally Posted by cfg83 View Post
BamZipPow -
CarloSW2
Plasti Dip should work then...
Old 01-29-2010, 10:09 PM   #20 (permalink)
ecomonkey
cfg83 is there any more to post from that article? have'nt found it on the web yet, noticed the front strake is flat on the inside edge , great info!
List of aero mods you can do to your vehicle MetroMPG Aerodynamics 148 08-12-2021 10:53 PM
Flashing yellow light skyl4rk EcoModding Central 5 08-01-2010 01:57 PM
News: VW to unveil 70 mpg (US) Golf diesel hybrid MetroMPG Hybrids 27 06-29-2010 07:50 AM
Sources of Aerodynamic Drag in Automobiles and Possible Solutions SVOboy Aerodynamics 12 02-17-2010 02:09 PM
Tire Engineer here - concerned about hyperinflating tires CapriRacer Introductions 48 09-26-2009 09:25 PM
