Old 05-16-2011, 08:34 PM   #11 (permalink)
Diesel Addict/No Cure
cleanspeed1's Avatar
StolenHoopty - '90 Honda Accord EX
HvyDrnkr - '93 Cadillac Seville
Maybe like the old Peterbilt 372?
http://farm5.static.flickr.com/4067/...42547098_z.jpg
Volvo WIA42 VED-12 / 335 hp / 1300 ft/lbs / 9 mpg
Big n' Boxy, Never met a Hill it Didn't Like
Old 05-16-2011, 08:37 PM   #12 (permalink)
Wow... why don't trucks look like that anymore?
Also...
Aerodynamics Research Revolutionizes Truck Design
The Following 2 Users Say Thank You to winkosmosis For This Useful Post:
cleanspeed1 (05-16-2011), landsailor (05-17-2011)
Old 05-16-2011, 08:42 PM   #13 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Welcome to EM!
Yes the back end makes more of a difference then the front end.
Old 05-16-2011, 08:43 PM   #14 (permalink)
In the case of the 372, it didn't sell well enough, albeit PACCAR didn't push hard on promoting it, especially since diesel was still dirt cheap when it came out. The traditional longnose conventional was what all the gearjammers wanted. And to think it was the first Class 8 to get 10 mpg loaded with a van trailer.
The ones that are left are getting bought up quick by those who know about them.
Old 05-17-2011, 06:58 AM   #15 (permalink)
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Toyota Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Versa Sedan 1.6 Base
90 day: 41.69 mpg (US)
A boattail will give you a big increase in fuel efficiency, but to do it right, you will need a long boattail, increasing the total length of your vehicle. Do you have an idea of how much longer you are willing to make your vehicle?
There may be some less lengthy options...
Nissan Versa Aeromods
Old 05-17-2011, 07:26 AM   #16 (permalink)
metroschultz's Avatar
CPT SLO - '93 GEO Metro plainjane
90 day: 53.91 mpg (US)
SilverHairBeauty - '01 Toyota Avalon XL
90 day: 24.06 mpg (US)
Send a message via AIM to metroschultz
Or make a boattail trailer?
Ala Aerohead.
When you are courting a nice girl an hour seems like a second. When you sit on a red-hot cinder a second seems like an hour. That's relativity.
Albert Einstein
The Following User Says Thank You to metroschultz For This Useful Post:
skyking (05-17-2011)
Old 05-17-2011, 09:24 AM   #17 (permalink)
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
Ala Aerohead.
Hey that is a brilliant Idea for this guy!
How about a boat tail trailer with some articulating gap fairings, inside is his favorite car? Maybe road bikes? That would really rock.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
Old 05-17-2011, 09:39 AM   #18 (permalink)
The windshield is an issue. A big expensive issue. I plan to build the nose of the front fairing to partially cover the huge windshield. It would cover the lover 12 inches of the windshield. This would change the pressure distribution on the windshield and might make it unsafe so I need to determine how a bullet nose on the bottom 2/3 will affect the pressure on the flat upper 1/3. I will take photos today.
Randy
Old 05-17-2011, 09:44 AM   #19 (permalink)
skyking's Avatar
I think you are missing the boat so to speak Randy. Forget the nose, concentrate on the tail. Cheaper, easier, more effective according to all accounts.
2003 TDI Beetle
2002 TDI Beetle
The Following 2 Users Say Thank You to skyking For This Useful Post:
crmears (05-17-2011), Frank Lee (05-17-2011)
Old 05-17-2011, 09:53 AM   #20 (permalink)
I imagine to make only a 6 or 8 ft. tail. My MH is 40 ft. long, 13 tall and 8 wide. and is a diesel pusher. The really huge radiator is at the extreme rear of the vehicle. Air enters the engine area from the bottom and flows through the radiator and into the vacume at the rear of the vehicle. I assume that the vacume is strong and produces a strong air flow through the radiator. This might be an issue in the design of the tail.
Randy
