11-10-2011, 01:23 PM
Pishtaco
Air conditioner disconnect circuit
Has anyone done this load-related AC compressor disconnect mod? It seems simple enough with the adjustable low voltage disconnect switch discussed in the article.
Unfortunately, the eLabtronics LVD switch appears to be unavailable from either Autospeed or eLabtronics. The articles are 3 years old, and clicking on purchase links leads to dead ends.
A search for adjustable LVD switches finds plenty of them, but they're all designed for battery switching in solar panel set-ups. None have the 0.1 to 4.5 volt trigger level needed to sense our TPS circuitry. I'm stuck. Any suggestions? I could probably build a circuit if given detailed directions.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
Mean Green Toaster Machine
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
11-11-2011, 12:17 PM
Pishtaco
I emailed elabtronics yesterday. No reply.
Darrell
11-11-2011, 12:49 PM
You should be able to make a circuit using a voltage comparator like an LM211 or LM311 to do what you want.
For reference, you can look up autospeed's closed loop monitor circuit. I believe they use a similar circuit to power that. It would work essentially the same.
The Following User Says Thank You to Daox For This Useful Post:
11-11-2011, 04:09 PM
looking at how that works I would use it as an automated alternator kill switch
11-12-2011, 01:26 AM
beamer - '91 bmw 318is 90 day: 32 mpg (US)
I wouldn't fool around with that system unless you know in intricate detail what each part is called, what it does and what it takes to replace it, how it works and how much it costs, which way the freon flows, what type and viscosity of a/c oil your car's system takes, which is the high and the low side and so on...
Maybe the only thing I can tell is you can manually control the compressor from cycling via the wires leading to the dryer / accumulator / receiver but it's generally only used for testing, you see where this is leading in terms of a failure, there exist several components to an automotive air conditioning system and if any of them fail you're looking at several hundred dollars and that's just for starters.
In most cases, the mere diagnostic of an a/c system costs north of $100,
that's just for them to TRY and find out what is wrong with it.
Don't be the next two thousand dollar a/c repair horror story, if you like your air conditioning to work, then don't fix it.
That having been said, by disconnecting the plug at the dryer / accumulator / receiver, the compressor won't come on at all.
11-12-2011, 02:13 AM
Pishtaco
Thanks, Daox. I should be able to use the closed loop monitoring circuit by having it monitor the TPS voltage, using the LED light signal as a triggering circuit to a relay to open the AC compressor circuit.
8307c4, I understand from your post I shouldn't shut the compressor alone. If I simply open the AC on/off switch with the relay, that should avoid your concerns, correct?
Darrell
11-12-2011, 03:45 AM
Wanting more for less
Is this kit the type of thing you are looking for?
"Car Air Conditioning Controller Kit"
Car Air Conditioner Controller Kit - Jaycar Electronics
The Following User Says Thank You to D.O.G. For This Useful Post:
11-12-2011, 07:44 AM
Chief - '06 Pontiac Grand Prix 90 day: 26.7 mpg (US) SF1 - '12 Ford Fiesta S 90 day: 30.95 mpg (US)
On my 1975 Camaro, I had installed a vacuum switch that simply opened the circuit to the compressor clutch. I didn't have any problems with the AC from that setup. As the clutch normally cycles on and off, I don't see any reason why it should cause a problem. But then the AC setup was much simpler than some of the newer systems.
11-12-2011, 08:55 AM
#9 (permalink)
Pishtaco
Originally Posted by D.O.G.
D.O.G.,
Yes, that's it exactly! Thank you. I've ordered a Jaycar kit for my car, and will also order the parts to attempt a scratch build of my own modified closed loop monitor for my wife's car.
Darrell
11-12-2011, 08:57 AM
#10 (permalink)
Cyborg ECU
I went looking just now and can see your jam-up. I tried changing some search terms, going for fewer, for more, for synonyms. No luck. This is a really interesting idea, though. I wish I could be more helpful. Good luck...
