Old 02-11-2019, 02:35 AM   #21 (permalink)
teoman's Avatar
A3 - '12 Audi A3
Wonder how much of a gain porsche obtained.
Old 02-20-2019, 05:51 AM   #22 (permalink)
Originally Posted by Isaac Zackary View Post
The goal has generally been to sync the intake going in for years with tube length and width in order to improve performance. But I understand that Porsche is doing the opposite and is getting better fuel mileage results due to cooling of the intake charge (air cools as you stretch it). Which in combination of a turbocharger still allows for a better intake charge than a normal engine. In other words, it's compressed by the turbocharger then stretched back out through harmonics in order to cool the intake without using a restrictive source like a throttle valve for each intake runner. This allows for greater boost, lower NOx emissions and better power and fuel mileage.
Boyle’s law tells us that if pressure in a gas is increased then temp increases (I can’t remember the ratio) and it cools as pressure is reduced so ‘stretching’ air - which I assume means reducing its pressure and therfore density would cool it back to the starting temp. You can’t (I’m pretty sure physics won’t let you) keep the higher pressure from the turbo and let the temp drop without somewhere for the heat energy to go like an intercooler.
Old 05-20-2019, 10:56 AM   #23 (permalink)
enator
Years ago, I tried that on a Sable wagon. Instead of connecting my HHO to the alternator, I hooked it up to two trolling/RV batteries. I also made a poor man's O2 sensor modification by putting about 0.1-0.2V bias to make the engine run leaner Also tried the oil anti fowler for sparkplugs on the O2 sensor. NO DIFFERENCE FOUND. A TOTAL WASTE OF TIME. I thought using the batteries, would make a poor man's hybrid, but HHO did not work at all.
The Following User Says Thank You to enator For This Useful Post:
Ecky (05-23-2019)
Old 05-20-2019, 12:18 PM   #24 (permalink)
teoman's Avatar
A3 - '12 Audi A3
Some dude on here was running around with a tank of hydrogen in his passanger seat.
His resuls also indicated no benefit.
The Following 2 Users Say Thank You to teoman For This Useful Post:
Ecky (05-23-2019), rmay635703 (05-21-2019)
Old 05-30-2019, 01:32 AM   #25 (permalink)
Exclamation
Oh my! results would be quite explosive in an accident!
Old 05-30-2019, 02:03 AM   #26 (permalink)
teoman's Avatar
A3 - '12 Audi A3
The things one does to find the truth...
Old 06-05-2019, 01:57 PM   #27 (permalink)
Pure hydrogen tanks cannot explode.
They can burn and cause a large plume of almost invisible flame. I watched the local Sheriff fire a 30-06 through various tanks. The propane/natural gas and hydrogen tank did not explode. They didn't even ignite. The gasoline tank did ignite and eventually exploded. The lithium-ion battery did too. This was for a county wide demonstration and training for first-responders as an introduction to various alternative fuel vehicle treatments.
Gasoline is by far the most dangerous fuel we use.
Old 06-05-2019, 04:12 PM   #28 (permalink)
90 day: 49.01 mpg (US)
but if a little bit of hydrogen leaks and mixes with the cabin air, that mixture will be explosive from anywhere between 4% and about 85% hydrogen.
You can't smell it or sense it in any other way. A few liters of the mixture could blow the glass out, a whole cabinfull would destroy other cars nearby.
It really isn't safe to carry a homemade hydrogen installation inside the cabin.
enator (06-15-2019)
Old 06-05-2019, 06:14 PM   #29 (permalink)
Other than a completely sealed enclosure . . .
. . . it is difficult to achieve a combustible mixture short of a gross failure in the valving or piping. This is due to the rapid rate of diffusion and the fact that it is lighter than air by a large margin. A leak of several liters per second in a car cabin with nothing more than a window cracked open just about eliminates the possibility of reaching 4% for the lower flammability limit.
How do I know this? From personal experience. I work with hydrogen all the time. It's dangers are overblown much like nuclear "waste".
