01-19-2018, 06:44 AM
Albuquerque electric bus problems
Saw on the local news that albuquerque public transportation is being accused of wasting hundreds of thousands if not millions of dollars on unreliable breakdown prone electric busses.
I'm waiting for a link to appear, I saw it on the local news last night, so it's still pretty fresh.
So far all the links are all older and full of rainbows and unicorns taking about how wonderful they will be.
01-19-2018, 10:45 AM
Probably not an isolated case. I just assume most anything the government is spending my money on is wasted.
01-19-2018, 10:58 AM
What part seems to be more failure-prone on them? Does the failure rate eventually have some relation to weather conditions? I've never been in Albuquerque or anywhere else in the U.S.A., but have always heard about New Mexico and Arizona having extreme weather conditions, and probably the low humidity in the air and the high temperatures become an issue due to the cooling of those modern Lithium battery packs fitted to modern EVs in general.
BTW some Chinese electric buses had been tested in my hometown, but probably won't be adopted by local bus operators so soon due to the local power grid being quite prone to weather-related failure
01-19-2018, 11:16 AM
Ecomodding Englishman
Major problem with the hybrid buses in London. The electric side is unreliable and prone to breaking down, thus leaving the diesels to run full time. Of course, the diesels were never designed to work that way and are pumping out more crap than the old buses did as the engines run flat out powering them.
https://themediocrecyclist.home.blog
2004 Smart Fortwo 0.7 petrol.
Motorbike.
Many, many bicycles.
2019 Volvo XC90 T8 - 400BHP plug in hybrid insanity.
All journeys I do under 10 miles are human powered - I make journeys, not excuses..
2019 mileage - 1900 by car, 7100 by bicycle.
01-19-2018, 11:22 AM
Are them using a serial hybrid setup? I'm only used to Volvo hybrid buses with their parallel hybrid setup.
01-19-2018, 02:07 PM
Now why would they do that? Every diesel I've ever seen puts out crap when it's accelerating, not so much when it's at steady load. Follow a semi as it downshifts going up a hill, for instance.
01-19-2018, 03:20 PM
Sonce this is coming out in the middle of winter I'm thinking it's probably not a excessive heat related problem.
The TV news didn't say what parts were breaking down.
01-21-2018, 08:51 AM
01-21-2018, 01:44 PM
#9 (permalink)
weirdo
should have gone with hydraulic
just hook up a large gearotor pump to the second back axle and add an accumulator
I could probably retrofit a bus myself for about 15,000
also amazing efficient on recovery of momentum with hydraulic
on the order of 92 to 98 %
01-21-2018, 03:55 PM
#10 (permalink)
Because they were never designed or optimised to function as the sole power units.
Motorbike.
