01-25-2016, 11:19 AM
#21 (permalink)
Originally Posted by Fat Charlie
Looking at the engine is a waste of time (other than to get it running in spec) until after he addresses the way the power gets used: aero losses, gearing and getting a handle on that 4 speed transmission. Changing the torque characteristics before you've got control over how the power output gets used is putting the cart before the horse- literally.
Correct, only modifying the engine if needed and AFTER changing the gearing.
01-25-2016, 04:51 PM
#22 (permalink)
Should I turn here...?
RE: the rear gearing: I'm pretty handy-- i.e. I have no qualms about changing my own oil, installing aeromods (obviously), fixing something if it breaks, etc.-- but in the big scheme of things, I hate wrenching. So if the current 4.10 rear axle is in good condition (which it is, afaik, since I had it apart to change the gear oil), I'm not about to take it off to put in something that is an unknown.
Also, I don't have a shop, which makes any mechanicking project into a have-to-get-it-done-before-it-rains-again project, which sucks even more fun out of it (Hooray for the pacific NW...).
I'll keep it in mind for the future, though.
01-25-2016, 05:21 PM
#23 (permalink)
MPGuino Supporter
iNXS - '10 Opel Zafira 111 Anniversary Suzi - '02 Suzuki Swift GL
You might could consider a coolant-based intake air heater. Both my Dodge Dakota's 4.7L V8 and my Dodge Magnum's 3.5L V6 have taken really well to heated intake air, it's a lot easier to plumb than trying to take heated air off exhaust parts, and I think that coolant does a better job of heating air than exhaust components do. I can get 90 to 100 F air going into the engine, when the outside temperature here is 0 to 10 F.
01-25-2016, 06:58 PM
#24 (permalink)
Heated intake manifolds were widely used in dedicated-ethanol versions of Brazilian cars, though they had a limited usage in gassers.
Makes sense, but some engine tuning is still worth considering.
01-25-2016, 07:26 PM
#25 (permalink)
Are you certain you have 4.10 gears? I think you might have 3.92's. 3.92 would be 1787rpm @60mph and 4.10 would be 1867rpm @60mph. 3.55's were optional, 1622rpm @60mph.
01-26-2016, 08:20 AM
#26 (permalink)
Rat Racer
Get me the VIN. There's a lot of information in there.
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
01-29-2016, 02:24 PM
#27 (permalink)
Does it even have overdrive? I thought the Ram Vans never got an overdrive transmission? Chrysler held on to the 3 speed automatics as long as they could.
01-29-2016, 02:53 PM
#28 (permalink)
Rat Racer
At least in that model year, the 32RH was only available with the 3.9 V6. The 5.2 and 5.9 V8s came with the 46RE.
01-29-2016, 03:05 PM
#29 (permalink)
Mmm. Chrysler 4 speed automatic.
Better save for a rebuild if it hasn't been rebuilt in the lats 30K miles ...
01-29-2016, 04:10 PM
#30 (permalink)
MPGuino Supporter
Or save for a manual conversion, instead.
