Old 05-29-2008, 11:08 AM   #171 (permalink)
silverciv - '01 Honda Civic EX 2dr
90 day: 36.13 mpg (US)
I think I might wire up the LCD in parallel and try to cut out the SoftwareSerial completely if I can.
Actually, I might be able to test without the LCD. Once the ELM has established a connection with the ECU, it will send a signal ever second or two to keep the connection alive and the OBDTX light flashes. If I run the code without software serial or an LCD, I should be able to see that light flash and the ELM maintain a connection even though I can't view the data.
Old 12-27-2008, 01:55 PM   #172 (permalink)
dkostas's Avatar
Masiniukas - '94 BMW 316i Compact
computer
I have a proposal for making almost perfect solution for fuel economy gauge/computer.
The MPGuino kit is a very cheep and nice device providing just enough info for monitoring things related to fuel consumption, especially for the older generation vehicles which do not have OBDII. However, to put a small LCD on your vehicle is not an easy task if you want to keep a good look of your car's interior and options for keeping history or uploading data to the web are also very limited if possible at all at the moment. The best monitor I think would be to transmit the real-time data to the more serious devices such as PC, PDA, Smartphone, etc. The most comfortable way would be to modify the current design so that we could hook a simple serial Bluetooth module to MPGuino board and use it instead of USB. Most of todays PCs, PDAs, Smartphones etc. has Bluetooth as de facto standard and the communication is as simple as with USB connection. Since MPGuino already sends processed data via serial link twice a second, we do not need to write complicated software. It is only the simple terminal needed to read Bluetooth serial port on PC, PDA etc. and show the info on the screen. I think once this step of integrating Bluetooth is made, the monitor software can be created practically in minutes on any platform, be it Palm, iPhone, Symbian, Windows Mobile, Windows, Linux, MacOS, etc.
If Bluetooth module integration is not an easy solution, then maybe it is possible to use Arduino BT version for MPGuino, however, the price difference makes it not so afordable at the moment.
Old 01-05-2009, 02:49 PM   #173 (permalink)
sukisuki - '00 Suzuki Grand Vitara 4wd
90 day: 21.88 mpg (US)
Wishlist/Features for OBDuino V2?
Guys,
is there an "official" wishlist, features list for the new OBDuino?
Here some ideas.
*Short term*
- extra analog sensors for mods (EGT, CHT, turbo, pressure for HHOs, ...)
*Mid term*
- intelligent curves comparison (for example how close is the car working compared to the theoretical best for that model). It might help early diagnosis of mechanical problems
*Long term*
- interface with GPS (for displaying only coordinates)
- Audio playback on USB/SD cards (so I can remove my stupid car radio once for all).
Old 06-21-2010, 09:20 PM   #174 (permalink)
Wink
Originally Posted by jim-frank View Post
I haven't read any comments on the retro analog approach, either. Something similar to an old tachometer circuit, using a bridge to balance injector pulsewidth against vehicle speed, maybe.
I don't know if anybody has seen the new Lexus sportscar but
it has really cool analog retro dials. Well, actually they are
digital because analog can't keep up with the motor lol..
An arduino could probably run a color LCD such as:
SparkFun Electronics - Color 24-Bit LCD 4.3" PSP Touch Screen
a cool analog display I am sure could be done..
The other thing is RGB LEDs. Don't know if people have
seen them. They are cool for doing mood lighting.
The pruis and honda whatever-it-is has these and they
go green when driving nice and orange when you push
the motor a bit.
My 12v RGB led strip has three wires, one for each color
and just needs PWM to vary the color. I'm just using some
resistors for now until I plug the duino to it.
Old 06-21-2010, 09:31 PM   #175 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Originally Posted by mpgx2 View Post
I can recall discussing "touch" switches : http://ecomodder.com/forum/showthrea...html#post18139
I think the result was that big clicky buttons in a predetermined location probably meant you could keep your eyes on the road more.
Old 06-21-2010, 09:54 PM   #176 (permalink)
Cool replication in software
I'm very sure that functionality like that can easily be replicated
in software.
Old 06-21-2010, 09:58 PM   #177 (permalink)
dcb
needs more cowbell
dcb's Avatar
lol, how do you feel a button in software, for peanuts?
Old 06-21-2010, 10:33 PM   #178 (permalink)
Cool button detection..
Simply check the voltage on the analog-in port on the arduino.
The buttons are wired to the analog in ports.
That's how you can check if the button is being pushed or not.
On a touch screen display, you read the coordinates of the
press.
On that psp display, you could use existing buttons and not
connect to the touch-screen circuitry. That way there wouldn't
be any major overhaul of the software necessary. But it's
really a matter of personal preference how it would be done.
Old 06-21-2010, 10:49 PM   #179 (permalink)
dcb
needs more cowbell
dcb's Avatar
you missed it. you cannot feel a software button on a touchscreen with your finger. And adding a beeper so you can get tactile feedback is a bit convoluted and burns another pin.
Old 06-21-2010, 10:59 PM   #180 (permalink)
Cool happy cheeful color LCD..
It doesn't need to be so complicated.
Just a bright colorful modern LCD display with big
digits for mpg. Add a splash of color for an extra $20.
No need for sounds.. touchscreens.. just keep the
existing tactile buttons where they are.
SuperMID - Fuel Economy Display SVOboy Instrumentation 25 05-15-2015 09:16 PM
How to calculate MPG / fuel economy formula MetroMPG DIY / How-to 29 11-25-2013 06:47 PM
What features on your ULTIMATE fuel economy instrumentation? MetroMPG Instrumentation 41 05-12-2012 01:14 PM
Why SUV fuel economy is so much more important than small car fuel economy... SVOboy General Efficiency Discussion 30 02-23-2009 06:26 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
