Old 03-15-2020, 03:24 PM   #11 (permalink)
90 day: 40.51 mpg (US)
I nearly built one a few months ago, even bought all of the parts and had them on my workbench. At the last minute someone on this forum offered to sell me a prebuilt unit, which is more compact and ultimately what I used.
Old 03-15-2020, 07:45 PM   #12 (permalink)
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
Originally Posted by racprops View Post
Well there are a number of Scan Gauges IF you don't mind getting your MPG from the OBDII Port. I have two versions: https://www.ebay.com/sch/i.html?_fro...cat=0....these are fine and well made. and as a cheaper version but seemly a little more complex is: https://www.ebay.com/sch/i.html?_fro...kw=turbo+gauge
This is a new one, looks interesting.https://www.ebay.com/itm/12V-OBD2-Ca...UAAOSwUrZd8ggE
The only need for a MPGunio is IF you tricking the car's PCM to improve its MPG and it some cases you might trick the MPG readings as well. Which is why I have them.
Rich
They said they had a 93, which is OBD1.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
Old 03-15-2020, 08:23 PM   #13 (permalink)
Sorry my bad, well this is for all running 96 or newer systems.
Rich
Old 03-16-2020, 06:11 AM   #14 (permalink)
teoman's Avatar
A3 - '12 Audi A3
That last ebay lik looks nice. A bit boxy.. but nice.
Old 03-16-2020, 09:13 AM   #15 (permalink)
I have one of each of the two first gauges, and like them. The Turbo gauge seems to have More features....
I also have a couple MPGunios, mainly because I had planed on doing things with the injectors, even one plan that might bypass the injectors so along with the above scan gauges I have a two of the very old Zemco automotive computer...sadly the great models I own are so rare I could not find any of them, not on ebay not in a wide search...just this older model: https://www.ebay.com/itm/Vintage-NOS...-/273868141978
Here is a picture of the great head unit in my 93 Chevy van. https://www.facebook.com/photo.php?f...type=3&theater
These work off its own VSS sending system by mounting a set of magnets to the drive shaft close to the transmission, and mounting a small coil close to them, running wires to your dash. this gives miles driven, MPH and is used to compute the MPG with a fuel flow sensor that is mounted in line from the fuel pump and the carburetor. This flow sensor tells the computer how much fuel that flows to the carburetor. With these two sensor these computers could tell you your MPG, MPH, range, as in miles to out of gas. And a few other read outs. There was a calibration needed, so for the first trips you needed to make adjustments to refine its readings.
I ran one in my 1974 Chevy van. It worked very well. During the gas shortage of the 70s having a read out to out of gas on road trips was a great help.
A few things I need to point out: These were low pressure systems, 5 PSI, I do not know how well the fuel sensor will work with 30 to 90 PSI systems.
Another problem with OBDI FI systems had fuel return systems, fuel fed to the fuel rail that was not used was bypassed and fed back to the gas tank. The fuel sensor cannot tell how much fuel was used by the engine. Even my 74 Van has a fuel return system but it was at the engine driven fuel pump so from this fuel pump was one fuel line to the carburetor so the sensor could read only the fuel fed to the carb.
I was trying to rig a aftermarket Fuel Pressure regulator that had a external fuel return that would allow the system to then feed the fuel rail as a direct line from this external fuel pressure regulator allowing the fuel flow to read the fuel fed to the fuel rail.
I did get this system rigged on my 93 Chevy van bypassing the TBI injector pressure regulator built into the TBI injector system, but ran into some kind of problem and ended up removing the system. The van runs at 10 to 20 PSI fuel pressure. It had no leaks at that pressure, I cannot say how it will handle higher PSI of other systems.
I also heard that the gas flow sensor did not have a great life, and can wear out, so was looking into better fuel flow sensors to handle higher fuel pressure system. I did not find one then.
Rich
Old 04-04-2020, 07:41 AM   #16 (permalink)
Greetings racprops
Like you I still have the same Zemco unit , I have used a few of these
Zemco systems since 1980 and have found their metering repeatability poor on
small engines(with carburettors) , also the internal seal fails eventually ,I have had to repair a few of these.
After about 5-7 years of service .
I also don't recommend more than 5 psi with these sensors due to the sealing
method used.
There was a conversion box available to convert these Zemco units to fuel injection
although I have never seen one ,it was listed in the owners handbook
Tp
Old 04-04-2020, 10:31 AM   #17 (permalink)
Thanks for your replay.
So where does these flow meters seals fail??
I once found a copy of the FI device circuit but I believed it failed to work.
It was a simple system to produce a ground pulse from a injector.
From the test system in the manual it should be very simple to make one, all they are doing is creating a temp pulse to ground, the test is to just ground the wire to these flow sensor a number of times and see it the computer show counts changing because of your tapping ground.
It could be as simple as hooking a bright white LED to a injector's ground trigger lead and putting it into a housing containing the flow sensor's light sensor light reacting diode.
I wanted it operating WITH the fuel flow sensor (of some kind) because I was going to trying some stuff to the cars computer that could product false readings and in a couple of possibilities that could by pass the stock fuel systems like fuel vapor.
So I was hoping of a system that reads the fuel used completely independent of any of the cars fuel management system.
I was hunting a high pressure flow meter to replace the unit that came with these systems. I am still looking for one.
I have read the BB used in these ware down, so that was one way it was reported to fail, and I bet these BB was not running though its track on low flow rates on your small engines.
Rich
PS I added a couple of photos of this flow meter here so we can agree we are talking about the same unit: https://www.facebook.com/richardacoy...e=3&uploaded=2
Originally Posted by TheTestPilot View Post
Greetings racprops
method used.
Tp
Old 04-04-2020, 07:43 PM   #18 (permalink)
Zemco carburettor fuel flow sensor
the 2 wires that exit the body is where they leak.Where these wires exit is the photo transistor , between the this & the fuel is a round glass window with some sort of sealing material to keep the fuel out ,I have one disassembled, I will try to post a photo. I think E fuel wasn't kind to the sealing material.
Old 04-04-2020, 07:53 PM   #19 (permalink)
Thanks. Darn, here I feared the big plate to plate would leak.
So now I KNOW I will need a better flow sensor.
Thanks.
Rich
Old 04-04-2020, 11:12 PM   #20 (permalink)
The reason I ended up here is to find a seller of mpguino,does anybody know what the previous sellers asking price was?
