Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 01-08-2013, 08:21 AM   #301 (permalink)
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 Nissan 720 KC 4x4 ST with fiberglass cap
90 day: 21.78 mpg (US)
Elroy - '03 Ford Focus ZX3 w/Zetec DOHC engine
90 day: 32.89 mpg (US)
Maybe you should sit down a create an organized plan for testing next spring after temps have stabilized (more or less) for the summer? Though figuring out how to mount the magnets and having them stay where you put them is a good thing....
If you haven't already...check out this thread for good info on mounting magnets....?
http://tech.groups.yahoo.com/group/d...se/message/372
I've usually used neo magnets in a series of 2 with a backing plate opposite the non-metallic fuel line...S facing the line.
Poster in this thread claims best to use S facing S with magnets opposite. He claims many variations on magnet positions were tested.
Just try this with a couple of larger neos.....you will need a good frame to hold them....
A frame could be made from a strap hinge bent so that after the 2 magnets were glued to the frame...it could be closed around the line...S facing S...and either taped closed or use an SS clamp to hold it closed.
For the air intake....N sides facing a non-metallic intake tube.
As far as the ceramic (weaker) vs neo (stronger) magnets being used...I've gone with the neos after trying some ceramics.
I have NOT tested magnet variations vs mpg results...just read a lot of patents and guessed a lot....
Carry on humans...we are extremely proud of you. ..................
Forty-six percent of Americans believe in the creationist view that God created humans in their present form at one time within the last 10,000 years. GALLUP POLL
Old 01-14-2013, 03:22 PM   #302 (permalink)
razor02097's Avatar
Tetanus - '95 Geo Tracker 4WD Base
90 day: 29.43 mpg (US)
300 - '82 Suzuki GS300 L
Last 3: 60.78 mpg (US)
Jeep - '98 Jeep XJ Cherokee Limited
90 day: 12.82 mpg (US)
I admit I didn't read the 31 pages but what are magnets on the fuel line suppose to do? Does it catch metal in the fuel that clogs injectors or something?
Project Avalon: E bike build
Old 01-14-2013, 11:10 PM   #303 (permalink)
It magically aligns the gasoline molecules (which are non-polar and non-magnetic) so that they burn more completely, because everyone knows that 90% of the fuel going into your engine actually goes out the tailpipe without being burned.
-soD
The Following 2 Users Say Thank You to some_other_dave For This Useful Post:
mcrews (01-15-2013), UFO (01-15-2013)
Old 01-15-2013, 04:50 AM   #304 (permalink)
Generally supposed to do something like what acetone might do...break up the larger clumped fuel molecules?
When I put magnets on fuel lines I try to never remove them for fear of loosening up any iron particles that have been gathered.
Old 01-15-2013, 08:34 AM   #305 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
yeap, that's it!!!!!
It catches them.....right where the magnet is.....all of them.....clogging up in one spot.........that's why you have to cut the fuel line every 3k miles and use a stronger magnet to pull them all out,,,,,,,,,,,kinda like clogged arteries.
Really, at least claim to read some of the pages.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 01-15-2013, 08:35 AM   #306 (permalink)
If magnets could break up complex, long-chain molecules, you probably shouldn't sit so close to your computer.
The Following User Says Thank You to niky For This Useful Post:
mcrews (01-15-2013)
Old 01-15-2013, 09:19 AM   #307 (permalink)
mcrews's Avatar
[QUOTE=suspectnumber961;349697].
I have NOT tested magnet variations vs mpg results...just read a lot of patents and guessed a lot...QUOTE]
Pretty much wraps that up......
can we close the thread down none.
ECO MODS PERFORMED:
First: ScangaugeII
Old 01-15-2013, 09:25 AM   #308 (permalink)
mcrews's Avatar
(I realllly cant believe you said that)
REALLY!!!!!!!
Dont all those 'iron particles' tend to clog up the fuel line!!!!!!
yeahhhh.......like clogged arteries.......
ECO MODS PERFORMED:
First: ScangaugeII
Old 01-15-2013, 09:51 AM   #309 (permalink)
justme1969's Avatar
The magnets polarize the fuel exciting its molecules b4 detonation. Only works if near the 49th parallel, following flare a solar radiation shower.
The Following User Says Thank You to justme1969 For This Useful Post:
niky (01-15-2013)
Old 01-15-2013, 10:09 AM   #310 (permalink)
mcrews's Avatar
And all along I thought it was pre- flare.........
who says you can't learn something here
ECO MODS PERFORMED:
First: ScangaugeII
Magnetic engine returns BillWhedon The Unicorn Corral 22 03-13-2013 03:09 AM
Uk ford transit, economy increase? chipX EcoModding Central 14 10-11-2012 02:38 AM
Magnets (as attachment method) jmonroe Aerodynamics 10 03-07-2009 01:12 AM
New Report of 20% milage increase by reducing viscosity of fuel htaylor EcoModding Central 29 01-27-2009 12:35 AM
magnets use for permanent mods ? groar EcoModding Central 5 09-08-2008 03:52 PM
