09-01-2010, 11:00 AM
#81 (permalink)
Originally Posted by bs0u0155
I also thought about adding in control from the brake lights. i.e. if the temp is above a set minimum, then the grill opens up whenever the brakes are applied, adding alight aero braking and "free" cooling.
Interesting idea. However, in winter this would not be ideal. You could do it if you still referenced the coolant temp and made sure it was above the thermostat open temperature.
09-01-2010, 01:48 PM
#82 (permalink)
Originally Posted by dustybarn
I'd suggest basing its control algorithm on ambient temperature rather than on coolant temperature (perhaps with overrides at low and high coolant temps). For example, the shutter might be fully shut at 30F and fully open at 100F, varying in between. The exact calibration would require experimentation. That way the grill opening would always be "just right" for the ambient temperature rather than being oversized at everything other than the maximum expected air temperature.
One could even consider a vehicle speed input so that the shutter gradually closes as speed increases.
I would guess it would only open above your lower setpoint, and you would still only cool to that lower set point, but the external temp could be used as above... or, you may be able to have it only open so far depending on outside temps, this may even be a manual input (3 settings, COLD (<30F, 1/4 open), nice (<70F, 1/2 open), HOT (>70F, full open)). Basically, the colder it is, the less it opens when actuated. The user figures out what temp to move settings. This would help limit the number of actuations.
Personally, I have thought that having the temps on different things would be nice. Coolant, Oil, Transmission, Ambient. If you kept the LCD interface (like the MPGuino) you could display all four to the driver. This would help with determining the above temperatures, and help the driver to make sure their other components don't overheat.
09-01-2010, 02:25 PM
#83 (permalink)
EV OR DIESEL
My thought would be
1)Coolant Temp
2) A/C On/ Off
3) Fans on High (so that when the A/C high side switch flips it would open wide.
Yes I use my A/C
That being said, a simpler approach could be coolant temp on/off switch + a tap on A/C fan High along with a pair of Diodes + a Relay.
Makes me want to break out the chopper gun and get to work.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
09-01-2010, 05:49 PM
#84 (permalink)
Do it! If you build it, others will follow! Daox has done a lot of the groundwork, but hasn't actually gotten it installed (to the best of my knowledge).
I know as far as I am concerned, I would like to have one, I have the abilities to copy/build the electronics, I have an idea on how it can be done (conceptually), but have no real understanding of how to do the programming. If someone shows me how, with a nice writeup and parts list, I would eventually get around to building one.
Oh, and as far as an AC fan/fan on high, you may be able to just tap into the wires running the fan(s) and get an LED to light on your dash (instead of having it displayed on the screen [if doing a screen]).
10-14-2010, 06:31 PM
#85 (permalink)
I'll begin working on a grill block soon for my Ranger. I've thought about some kind of open/close system. Engine over heating is not worth a few temporary mpg's; especially with a truck that might be used for hauling heavy loads. I am amazaed when I read about people who do a belly pan and full grill block, then act surprised when they blow their engine.
10-14-2010, 07:53 PM
#86 (permalink)
I have yet to hear anyone whose blown their engine...
10-15-2010, 04:17 AM
#87 (permalink)
The only blown engines i hear about are those that redlined while turning around in circles or drove through a deeply flooded road.
But i suppose the point was that care needs to be taken with full or almost full grille blocks. You cant fit one and forget it. A bit of thought has to be put in. I have to remove mine whenever my wife drives my yaris. I don't know how she drives it but she got it fairly hot one day.
10-16-2010, 05:11 AM
#88 (permalink)
Look closely at recent cars - at least the European ones.
The grille blocks are already built in
It's not too obvious, but they all block those gaping holes from behind.
10-31-2010, 10:31 PM
#89 (permalink)
large trucks have been using shutters behind the grill for years.
06-09-2011, 03:53 PM
#90 (permalink)
Originally Posted by davidgrey50
I'm new around here, so excuse me if this idea has already come up. It strikes me the only time you'd want the grille door open is at a high coolant temp, which is exclusively a problem at low speed, and that you'd want it closed at lower coolant temp, which would generally occur at higher speeds. So hows about a nice simple spring-loaded flap which would stand open at low speeds and push closed at higher speeds?
A little experimentation with spring rates would allow opening and closing at a desired temperature.
I know there has to be a simply engineered solution I'm missing, but how do you get a spring-loaded flap to open under low pressure and close under high pressure?
