Old 05-15-2017, 01:53 PM   #121 (permalink)
I like the balanced vane blade. Would a worm gear and a small (stepper?) motor work?
Thanks Neil.
I'm sure we could make this work with a small stepper motor.
Old 05-15-2017, 02:32 PM   #122 (permalink)
teoman's Avatar
A3 - '12 Audi A3
You could mount the servo on to the flap
Stepper will also work but servo is better suited for the application i think. It is absolute position control vs relative. With the stepper you either need a limit switch or you need to force stepper several steps over open an close, making it skip steps so that you get an absolute position reference.
The Following User Says Thank You to teoman For This Useful Post:
Daox (05-15-2017)
Old 05-15-2017, 02:35 PM   #123 (permalink)
Haha, thats pretty clever!
Old 05-16-2017, 09:41 AM   #124 (permalink)
Alright, I got it all mounted and on the car last night. Unfortunately it rained and that slowed me up a bit.
Time for pics!
Traced the grill block on to the coroplast. I cut it with an exacto blade after that, and drilled holes in the coroplast.
Cut and mounted with screws. Fit great. It did require a bit of notching around the servo and its arm.
Here is the back side with servo mounted.
Soldered up the wire that will run to the arduino in the cabin. I used a 4 conductor telephone wire.
I could use a good way of making this connection water tight... Suggestions welcome!
After that it was a matter of waiting for the rain to stop and going and bolting it on. It really fit nice.
Once its painted I don't even think it'll be real noticeable at all.
The white is paper that stuck to it when I superglued it together. It will be cleaned up when I go to paint it.
View from the front of the car. Its a bit behind the license plate, but I can't really shift it any further to the right due to the wood blocks needing space.
ID:	21778   Click image for larger version
ID:	21779   Click image for larger version
ID:	21780   Click image for larger version
ID:	21781   Click image for larger version
ID:	21783   Click image for larger version
ID:	21784   Click image for larger version
ID:	21785   Click image for larger version
The Following 6 Users Say Thank You to Daox For This Useful Post:
BamZipPow (05-16-2017), Ecky (05-16-2017), IamIan (05-26-2017), NeilBlanchard (05-16-2017), samwichse (01-04-2019), t vago (05-16-2017)
Old 05-16-2017, 11:18 AM   #125 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Dielectric grease goes along ways at waterproofing connectors. Add some shring tubing over it and yer good to go.
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following User Says Thank You to BamZipPow For This Useful Post:
Daox (05-16-2017)
Old 05-16-2017, 11:57 AM   #126 (permalink)
Veen's '09 FIT - '09 Honda FIT Sport
Wagons
90 day: 43.41 mpg (US)
Doax,
Do you have the design files?
I'd like to take a shot at designing the parts for laser cut but keep compatible with your design.
It'd be nice to have a sort of "standard" for this that could be repeated easily.
Old 05-16-2017, 01:23 PM   #127 (permalink)
I did get the grill block partially wired and powered by the car. There are still some wiring tweaks to make. Its not hooked up to the coolant sensor yet, so I'm just running the demo sweep program.
I noticed on the trip in today that I must have pulled 12V power from the wrong pin because I have some funky IMA error code (P1647). I'll have to get 12V switched from somewhere else.
The Following 2 Users Say Thank You to Daox For This Useful Post:
BamZipPow (05-16-2017), yarisbaby (01-06-2019)
Old 05-16-2017, 02:10 PM   #128 (permalink)
Originally Posted by Veen View Post
Doax,
I'll PM you about it. I don't think the design can easily be laser cut. The lines you see separating the parts are not vertical, they have internal geometry that you don't see that centers the pieces as they snap together. This vastly increases the rigidity when things are put together.
Old 05-17-2017, 10:15 AM   #129 (permalink)
Last night I got it all wired up. I had to make two connections to the ECU. One was for the coolant temperature signal, the other for power. I was able to find a 5V power pin on the ECU, so I used that. That'll reduce losses with power regulation.
So, the arduino sits in the glove box for now. I didn't get a chance to upload the program to it and try it on the trip in today. Plus, I still have a few programming tweaks to make. I'll post the code later today hopefully.
ID:	21789   Click image for larger version
Old 05-17-2017, 04:20 PM   #130 (permalink)
...beats walking...
Is it "slap-bang" (OPEN/SHUT) or proportional (variable) opening?
