01-08-2008, 07:57 PM
This thread is in the EcoModder Project Library |
Autospeed article: adding a chin undertray to a 1st gen Prius
( Note: see also Adding front & rear undertray to 2nd gen. Prius )
From the Australian web magazine Autospeed -
Some of you may have seen these already... Modifying Under-Car Airflow, Part 1
Modifying Under-Car Airflow, Part 2
Originally these articles used to be pay-access only, but they've opened them up for public access now.
The project documents the creation of a prototype front partial undertray for a 1st gen Prius, testing, and then fabrication of a permanent version.
Before:
Mockup:
Final version:
The writer reports a 10+% improvement in fuel economy at freeway speeds (100km/h) with the mod in place. I frankly find that a bit difficult to believe, though I don't doubt there was some improvement.
If you read the article you can find a few holes in his testing approach - even though he's fairly aware of things like experimenter bias, and aiming to perform tests on the same day (for consistent weather conditions).
The articles also give a good background on the subject of under car aerodynamics. Definitely worth a read if you haven't seen them yet: Modifying Under-Car Airflow, Part 1
01-14-2008, 08:26 PM
These are great articles
Sure their testing left something to be desired.
And I would question their results.
C'mon ten percent improvement?
However, I can see how I could apply what I learned in this
article to the '94 Honda Accord I currently drive.
Thank you, MetroMPG for finding this article.
01-14-2008, 08:29 PM
Good stuff, Metro...thanks for sharing!
Best tank ever: 72.1 mpg in February 2005, Seattle to S.F.
New personnal best 'all-city' tank June '08 ... 61.9 mpg!
Thanks to 'pulse-n-glide' technique.
01-15-2008, 03:36 PM
I"m not lurking!
Ditto. Thanks for dredging that up, Metro.
I noticed they use "high quality" duct tape for their mods. Something we home DIY'ers can shoot for. I tend to use black duct tape, so it matches the trim on my car. A real consideration, since my temporary grill block stayed on the car for six months.
IMHO, they are not hard-core hypermilers, though. I see they chose stability over low drag. Wimps.
Thanks again,
Stew
Roll on,
Stew
01-15-2008, 03:57 PM
I know!
When I read the bit about the front tire deflectors they also tested along with the undertray, I couldn't believe it they concluded: they also reduced drag, but made the front feel end lighter, so we ditched them.
01-15-2008, 07:12 PM
Yikes!! My Aveo has absolutely NO chin undertray!! I can see clear up to the hood from under there. With grill blocks, maybe I can top their 10% WOO HOO!! Weekend project!!
01-15-2008, 07:29 PM
It may not need one as much as this Prius did.
It's not so much an issue of being able to look up & see the hood, as it is directing airflow more cleanly past the bits of the car that stick down below the bottom edge of the front bumper.
01-15-2008, 07:37 PM
I'll have a look when my Mother in law is done borrowing it. As I recall though, it isn't especially aerodynamically clean under there.
01-15-2008, 07:45 PM
#9 (permalink)
I"m not lurking!
BTW. I noticed the undertray on my wife's Taurus while I was working on it, and got undertray envy. So I grabbed one off a Taurus last time I was at the junkyard. It's not solid; it has a couple of slots in the middle to allow air for cooling, I guess. It feels like really thick polyethylene. Should be easy to cut down and fit on my Cavalier.
Roll on,
Stew
The Following User Says Thank You to s2man For This Useful Post:
01-15-2008, 08:57 PM
#10 (permalink)
Giant Moving Eco-Wall
Duct tape is AMAZING
