Old 05-11-2008, 08:23 AM   #11 (permalink)
Why paint it? The naked screen should be adequate to smooth the air flow, while allowing the exhaust system to vent heat. And, aluminum screen being about the world's best heat conductor, it will dissipate heat from any contact with mufflers, etc..
Or, you could use Coroplast along both sides, with aluminum screen just to cover the central tunnel and exhaust pipes/mufflers. The Coroplast could act to clamp the screen in place, nice and taught.
Old 05-11-2008, 10:22 AM   #12 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
I could only speculate that the paint might make the screen hold better. Isn't tearing of the material the main problem with screen bellypans?
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 05-11-2008, 11:01 AM   #13 (permalink)
An area under the cat,muffler and pipes was left unpainted.
The paint cost nothing as it was on hand, hence the "kitchen yellow" color.
AND it probably does improve airflow. Adequate is not enough for anything but Gov't work.
Old 05-11-2008, 02:11 PM   #14 (permalink)
Originally Posted by edbso View Post
An area under the cat,mufflet and pipes was left unpainted.
The paint cost nothing as it was on hand, hense the "kitchen yellow" color.
Please keep us posted regarding before and after fuel economy, noise, etc. I'm seriously considering modding my BMW 325is in similar fashion.
BTW, what kind of glue did you use?
Old 05-11-2008, 04:38 PM   #15 (permalink)
MechE
The Miata - '01 Mazda MX-5 Miata
I hope you're working with that thing on stands - not just supported by the jack o.0
Looks promising though
Cars have not created a new problem. They merely made more urgent the necessity to solve existing ones.
Old 05-11-2008, 11:42 PM   #16 (permalink)
Thanks for looking out for me.
I use a 3 tone jack and stands with a wheel block.
Old 05-13-2008, 11:18 PM   #17 (permalink)
Observation:
The car is quiter.
Wind noise reduced
as well as induction and or exhaust noise is decreased.
I also have found the CleanMPG.com and entered my recent gas log.
Old 05-14-2008, 12:49 AM   #18 (permalink)
To me, noise reduction alone would seem to make this a worthwhile experiment.
The screen, in addition to making smoother airflow under the car and less noise in the first place, probably also reflects and absorbs noise by acting as an acoustic barrier of sorts. A smoother screen with better acoustic absorption would probably work even better.
Your aluminum windowscreen fabric is a great idea, and the price is right. To make it super-smooth after fitting it to the car, you could then use a flat table covered by smooth glass or plexiglass: Pour plastic resin such as polyester on the flat table and spread it evenly. While the resin is still fluid and before it sets up, secure the pre-fitted aluminum screen to the table, such that the resin penetrates and forms a matrix with the screen fabric. (A vacuum bag would help lots with this.) Once the resin hardens, peel the matrix off the table, and the hardened but flexible resin will retain the smooth texture imparted by the table top. Put the pre-fitted screen back on the vehicle for a super-smooth finish.
Old 05-14-2008, 08:43 AM   #19 (permalink)
Blue - '77 Chevy P/U
you have pics of the vacume bagging ???
Old 05-14-2008, 10:11 AM   #20 (permalink)
ScabbySentra - '93 Nissan Sentra SE
90 day: 44.37 mpg (US)
There are some nice tutorials at the WISIL site, including one on vacuum bagging at http://www.wisil.recumbents.com/mars...FS00intro.html
Metro undertray / belly pan MetroMPG Aerodynamics 47 03-13-2014 05:13 PM
Vortex generators - where's the solid data for hatchback/van benefits? MetroMPG Aerodynamics 70 03-14-2012 12:25 PM
Honda's OEM vortex generators ... on the Ridgeline pickup mirrors MetroMPG Aerodynamics 21 12-06-2008 01:09 PM
More than one Vortex too! Christopher Jordan Fossil Fuel Free 2 02-17-2008 07:57 PM
Plant Stand Vortex Generators? cfg83 Aerodynamics 7 02-14-2008 11:11 PM
