12-11-2018, 02:08 PM
#241 (permalink)
Master procastinator
Recently bought this beauty from a thrift shop for 30 euros. Plan is to put new tires, saddle, brake pads and that handlebar strap-thingy whatsit.
This bike is finnish made, Nopsa President 12-speed. No clue what year it is.
12-11-2018, 02:34 PM
#242 (permalink)
It looks light. The welds suggest an aluminum frame.
12-11-2018, 02:41 PM
#243 (permalink)
latest junk bike
Sadly, my second Pirate Bike disappeared a week ago. This will be its replacement as my around-town junk bike:
This is my 5th junk bike that was being thrown away by a neighbour. (By now the neighbourhood should know to just drop off the old bikes at my driveway!)
Needs: blinky lights, mirror, splash guards, rear basket.
Sadly, it's only a 6-speed. Its predecessors were 18 & 21.
12-11-2018, 05:14 PM
#244 (permalink)
The Nopsa tubing diameter looks like a steel frame compared to my aluminum Jamis Aragon. A quick check with a magnet tells the tale. Most peole lose the inboard brake levers. I put extra padding under the handle bar tape.
In the relatively flat 1000 islands a 36T or 38T chain ring and a 28T rear should be adequate. The only time I use my low 28T chain ring is on our elevated bridges or steep hills. But then I'm getting old.
12-11-2018, 06:48 PM
#245 (permalink)
You are correct, sir -- all steel. It's a bottom-rung cheap department store bike.
The gearing is adequate, yes. But I'm lazy, and I find I'm missing the granny gear the previous bike had!
12-12-2018, 12:15 AM
#246 (permalink)
Freebeard and Grant, i had to go inspect the bike with a magnet. Steel frame allright, all the other bits and pieces are aluminum though.
And yes, it is fairly light too.
12-12-2018, 02:30 PM
#247 (permalink)
I was phishing for a weight.
In my defense it was a small picture. The weld look unfilleted, as aluminum frame usually are. Aluminum often has a bigger oval down tube.
12-13-2018, 02:24 AM
#248 (permalink)
11.3kg, measured on a people-scale so maybe not the most accurate result
The Following User Says Thank You to iikhod For This Useful Post:
12-13-2018, 09:35 AM
#249 (permalink)
11.3 kg is about 25 lb. That is common for this type of bike. I have done testing and calibration as an engineering tech for 25 years. You never know what will surprise you next. That's why we say "test don't guess". I consider freebeard and MetroMPG master ecomodders of good reputation.
The Following 2 Users Say Thank You to Grant-53 For This Useful Post:
01-06-2019, 04:51 AM
#250 (permalink)
Stopped for some water on my usual route.
This is my new to me-mtb i got couple of weeks ago, white xc275 lite with the 21"frame.
