Old 07-09-2019, 08:12 PM   #11 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
I would hesitate to go any lower than you have already; generally, there's a "sweet spot" where CD goes down as the body is lowered, but rises again with more lowering. According to the aerodynamics textbooks I've read, this is somewhere around 0.75 body cover:1 wheel diameter.
Mirrors will be your best bet. That underside looks very good for a production car already, but you may be able to cover the opening at the front subframe and behind the motor at the rear (or is yours a REx?).
Good luck! There are a couple of these running around my town, and I love seeing them--especially since the carbon fiber used in the body was manufactured in my hometown of Moses Lake.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
aerohead (07-10-2019)
Old 07-09-2019, 08:55 PM   #12 (permalink)
Lord Vader - '15 BMW i3 REx
90 day: 35.06 mpg (US)
Agreed. I don't think there is much to be gained there, although I am also looking at adding a front splitter. The front bumper profile rounds under relatively smoothly, but that would reduce some of the pressure and lift I get under the front end at higher speeds - and hopefully clean up aero overall.
It is a REx, so it does need to breathe a bit, but I wonder if just adding an exhaust louver over that rear most opening flat with the rest of the covering would help. Supposedly the REx version has a 0.01 cd penalty, and I can't figure any other place that could be coming from aside from that opening.
2015 BMW i3 REx
2011 Ford Flex SEL AWD
The Following User Says Thank You to Snax For This Useful Post:
Old 07-09-2019, 10:16 PM   #13 (permalink)
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 61.75 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
90 day: 38.2 mpg (US)
Mirror delete and wheel skirts, as noted before. Filling in any part of the underbody that isn't completely smooth, covering up that opening in the front of the car beneath the "grille", for aero. Maybe a kammback if not a full boat tail.
I wouldn't go extreme and do something like shave the door handles on a car that expensive just for another 0.01 MPG, but YMMV.
Tire pressure and slow speeds are probably your best bet for improving range with that car.
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
Old 07-09-2019, 10:32 PM   #14 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
My money would be on mirror delete, but what do I know. Rear wheel covers could be it.
I don't disagree that the mirrors are a good mod to attempt. But in thinking about the lowest fruit, I include complexity and reversibility and possible police hazzards. One can experiment with wheel well covers almost for free, using cardboard, then build with materials much cheaper than cameras and much less likely to get a cop on you. That's all... the A2 windtunnel experience & results are relevant here, probably.
The Following 2 Users Say Thank You to California98Civic For This Useful Post:
NeilBlanchard (07-10-2019), redpoint5 (07-10-2019)
Old 07-09-2019, 10:35 PM   #15 (permalink)
Unfortunately, I don't believe any kind of a block of that front opening is a good idea except for perhaps during winter, as the car actively cools the battery during driving and charging from the heat pump radiator up front. While that kind of thing is relatively easy to monitor with an ICE motor, battery temperature is a black hole of information for owners and constant overheating would most definitely shorten the life.
2015 BMW i3 REx
Old 07-09-2019, 10:41 PM   #16 (permalink)
Is the battery in the front of the car then? If it's for battery cooling then definitely leave it open; maybe duct it a little better since most factory ducting is subpar at best. Usually the batteries are underneath the car or more toward the rear.
Old 07-09-2019, 10:43 PM   #17 (permalink)
I had not seen that chart yet. Great info.
Fortunately I don't have to worry about legalities with the mirrors, as Oregon law is fairly arbitrary requiring only a "clear view" of the rear, and no specifics as to the number or placement of them.
I'm definitely going to delete them, as they are a noticeable source of noise at highway speeds. I think I have decent cameras and a monitor picked out to take up the slack - and hopefully actually expand my field of view at the same time.
Wheel covers are the likely to be my first step nonetheless, since it costs next to nothing to try.
2015 BMW i3 REx
Old 07-09-2019, 10:45 PM   #18 (permalink)
It is underneath, but uses a heat pump to circulate coolant through the system.
2015 BMW i3 REx
Old 07-10-2019, 12:52 AM   #19 (permalink)
2020 - '08 Chevy Tahoe H
Last 3: 18.4 mpg (US)
2021 - '08 Chevy Tahoe H
90 day: 17.08 mpg (US)
2022 - '08 chevy Tahoe LT
Last 3: 14.38 mpg (US)
2023 - '08 Chevy Tahoe
Last 3: 22.61 mpg (US)
2024 - '08 Chevy Tahoe
90 day: 22.35 mpg (US)
Ha ha, yeah . . no . .
I was just looking under the rear area ahead of the bumper, and it looks like they did wrap everything up like a diffuser, but it lacks side dams. I might try hot gluing something on down there to test out as that seems like one of those things they would likely have compromised out of the design for durability considerations.
All else on the car is otherwise so clean that substantial gains seem most likely to be with either my driving or the boat-tail I am so against.
Anyway, unless people have other suggestions, I will probably stick to this thread for whatever mods and testing I do.
well you could not drive at all and take the bus to get more mileage
Old 07-10-2019, 12:54 AM   #20 (permalink)
Found the pdf for this study BTW.
2015 BMW i3 REx
