12-26-2013, 01:11 PM
#111 (permalink)
T-100 Road Warrior
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following 2 Users Say Thank You to BamZipPow For This Useful Post:
12-26-2013, 02:47 PM
#112 (permalink)
T-100 Road Warrior
The Following User Says Thank You to BamZipPow For This Useful Post:
12-26-2013, 04:38 PM
#113 (permalink)
T-100 Road Warrior
A quick drive around town reveals that the top gap cover is staying down and in place while at speed. Not sure how much air will cause it to flip up but I'm not gonna worry about it too much as the cover can't flip up and over on the hatch so it should fall back down on its own.
Where the longer 48" cover was flipping up on the outside edges, I haven't noticed the 24" long flipping or fluttering at all.
12-27-2013, 04:34 PM
#114 (permalink)
T-100 Road Warrior
12-27-2013, 05:51 PM
#115 (permalink)
project
Bam,she's really comin' together! Happy that the 'pick and shovel' work is behind you,and that you can 'play' with the details.
12-27-2013, 07:05 PM
#116 (permalink)
T-100 Road Warrior
Ended up with some rubber feet instead of the teflon ones. After I installed them, I had to adjust the back metal strips in the back to allow fer clearance when the trailer slides/wiggles in the back. The feet promptly snagged the flashing protection and ripped up one edge. Guess I'm going without any sort of protection on top. Maybe some grease will help?
No noise from the feet as far as I can tell. Looks like it's a keeper.
12-28-2013, 09:21 PM
#117 (permalink)
T-100 Road Warrior
Disaster! Left one of the landing legs down and didn't realize it until the wheel was completely ground away. Looks like I'll be hunting down a welding shop to weld a plate on the leg as I do have a spare wheel with me.
Got an indicated 27mpg just 1.5 hours out from home. Currently sitting at an indicated 26.6mpg out to Lafayette, LA.
12-29-2013, 03:35 AM
#118 (permalink)
T-100 Road Warrior
Drizzle and rain has dropped the indicated MPG down to 24mpg on the drive to Biloxi, MS. No other problems so far.
12-29-2013, 11:25 AM
#119 (permalink)
B-b-b-ut you had a checklist!
12-29-2013, 10:46 PM
#120 (permalink)
T-100 Road Warrior
Got an indicated 26.7mpg from Pensacola to Jacksonville.
