Old 08-29-2008, 09:21 PM   #1 (permalink)
Guzzler Driver
nitrogen's Avatar
Guzz - '03 Infiniti I35
90 day: 22.73 mpg (US)
Built-in MPG calculators - Is yours as much of a liar as mine?
I thought I was doing well, going by the built in computer in my car.
nope. Apparently it's a big ole liar. What's up with this? Are other cars' built in computers liars too? Is the scanguage better about this than the built in computers?
EDIT: It's a liar, telling me I'm doing BETTER than I really am, to clarify...
Old 08-29-2008, 09:34 PM   #2 (permalink)
testing the waters
How much was it off by?
Old 08-29-2008, 09:36 PM   #3 (permalink)
Guzzler Driver
nitrogen's Avatar
5.5mpg.
Old 08-29-2008, 11:27 PM   #4 (permalink)
Who
UnderModded
Pablo - '07 Hyundai Santa Fe AWD
90 day: 23.62 mpg (US)
I've never heard of one ever being pessimistic, but that's a huge diff!
Old 08-30-2008, 09:05 AM   #5 (permalink)
EcoModding Dilatant
Volvo - '00 Volvo V70 XC AWD SE
90 day: 27.7 mpg (US)
My Volvo's computer consistently indicates worse average mileage per tank than I've really gotten. it's usually off by about -2 mpg. The speedometer and odometer readings are exactly right as measured by my GPS, so it isn't some strange tire diameter issue.
I would guess that OEM computers use a standard factory calibration value that can be a bit +/- for any particular car (but 5.5 mpg does seem like a lot). An after-market guage could be better or worse, depending on how well you calibrate it.
Old 08-30-2008, 10:28 AM   #6 (permalink)
Guzzler Driver
nitrogen's Avatar
See, mine tells me I'm doing BETTER than I am, which is even MORE confusing.
I wonder, since I run Regular, and it likes Premium, if it doesn't take the automatic timing retardation into account.
I'll be interested to see how much better I can do with a scanguage.
Old 08-31-2008, 09:16 PM   #7 (permalink)
Nerdcycle - '81 Honda CM400E
Motorcycle
90 day: 61.16 mpg (US)
Trouble - '06 Kawasaki Ninja
90 day: 74.69 mpg (US)
Edna - '13 Nissan LEAF SV
Last 3: 126.4 mpg (US)
Tank - '20 Ford Expedition Limited
Last 3: 17.4 mpg (US)
Our Jeep is the same way. The average reading will say 13-14 and miles traveled divided by gallons is more like 11-12. Sometimes it's better than others. I started reading up on why and found out that the average is only the average over the last 50 miles! So if I drive it for the first 200 miles then my wife, the last 50, it's about on, since the readout is still optimistic. The other way around, it's just WAY optimistic.
Old 08-31-2008, 11:22 PM   #8 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 Scion xA
90 day: 42.72 mpg (US)
I remember reading some posts on CleanMPG that Toyota built-in MPG meters are notorious for being too optimistic (ie higher MPG than it should be). Not sure what would account for these discrepancies but this is why nothing beats the odometer-tank fill method of MPG tracking.
But at least you know now that the meter is higher than it should be so you have a higher "target" MPG to aim for and stay at. This is also why I keep a little sheet with estimated miles at 1/4, 1/2 and 3/4 empty on my tank and their respective MPG values. That way I can see if my scangauge is close or off from what my fuel gauge/odometer is telling me where I should be at.
For example, with a half empty tank (5.5gal), I expect at least 220 miles on the odometer for a ratio of 40 MPG/tank.
My 5 pillars of fuel efficiency:
  • driving style
  • aerodynamics
  • tires
  • weight reduction
  • engine maintenance
Old 09-01-2008, 04:48 PM   #9 (permalink)
EcoVibe - '07 Pontiac Vibe base
90 day: 38.14 mpg (US)
I've tracked mileage by log against my other car and it is off a little (like 1-2mpg)... but nothing like you are seeing at 5.5mpg. Weird
Old 09-02-2008, 01:07 AM   #10 (permalink)
E-Class - '04 MB Mercedes E320 4Matic
Matrix - '09 Toyota Toyota Matrix 2.4L AWD Sports Package
My MB E320 also has a meter that is slightly too optimistic. The difference is much smaller than 5.5 mpg though.
I wish my Toyota Matrix also had a meter but it does not, which is bad.
Question regarding Scangauge MPG readout & DIY device Gregte DIY / How-to 5 05-19-2008 04:58 PM
School teams to compete in cross country MPG Challenge - Possible $1,000,000 prize ericbecky EcoModding Central 9 03-22-2008 09:15 PM
