12-19-2011, 05:45 PM
"Bumps" on OEM Subaru Impreza roof racks supposedly improve MPG
Stumbled upon this video of the 2012 Subaru Impreza. At the 30 seconds mark, the guy talks about the roof rack and its design. The added "tab" at the end of the roofrails added 1 MPG to the highway fuel economy as per their aerodynamic testing. Apparently it smooths the airflow. I find that aerodynamic tweak amazing given its small size and its correlating impact on fuel economy.
12-19-2011, 06:12 PM
VG
The tail end of the rack ends just where attached longitudinal vortices might form off the roof.
The tail of the rack sections are just like a Mitsubishi Lancer roofline (very steep!) and the 'bump' should act just like a vortex generator to help the flow follow that steep incline.
Also,EPA Mobile Sources certification testing includes faster speeds ( up to 70 or 75 mph) than in past decades,so drag is more important than ever before and 'small' differences would matter.
12-19-2011, 07:02 PM
EcoModding Dilatant
Volvo - '00 Volvo V70 XC AWD SE 90 day: 27.7 mpg (US)
1 mpg? I find that hard to believe.
12-19-2011, 09:19 PM
T-100 Road Warrior
Keep in mind that engineers probably gave the marketing people the numbers and the marketing people rounded up. So it might have been some fractional gain...
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following User Says Thank You to BamZipPow For This Useful Post:
12-22-2011, 10:13 AM
I'm skeptical about their claim too. Needs some fact checking!
12-22-2011, 10:56 AM
I agree that it might be a vortex generator of some kind which alters the flow over the car, or creates it's own small vortex which affects the larger one which would normally form.
I did some studies on pick-up truck roof cabs which intended to do something similar. However I am far away from doing something about it (spring project), and even farther away from proving how or why it may work.
Anything which lowers the air pressure at a critical point (aft) will result in sucking the air above it (at higher pressure) down. In the end, it will appear as though the overall flow is better.
12-22-2011, 01:15 PM
Quasi-Modder
Anyone know of any bridges for sale in Brooklyn?
12-22-2011, 03:38 PM
#9 (permalink)
What are the chances of Subaru releasing the test results in order to prove the 1 MPG-benefit claim ?
12-22-2011, 04:00 PM
#10 (permalink)
