Old 06-13-2011, 11:55 AM   #11 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
Originally Posted by cfg83 View Post
CapriRacer -
I didn't know that. That implies (to me) that a 44 PSI max tire would blow up at around 132+ PSI (3 * 44).
CarloSW2
IF they derate linearly. And IF truck tire construction scales to passenger car tires.
I'm not saying they are bad assumptions, just that they are assumptions.
I'm not coasting, I'm shifting slowly.
The Following User Says Thank You to UFO For This Useful Post:
cfg83 (06-13-2011)
Old 06-13-2011, 04:11 PM   #12 (permalink)
99SL2AT - '99 Saturn SL2
Volvo - '04 Volvo V70 2.5T
I don't think they scale. Truck tires: 12+ plies, tapered bead, steel belted sidewalls.90-120 psi Average passenger tire: 4 plies, nylon, rayon, polyester.........sidewall. 35 to 51 psi.
As far as inflation goes.....most cheapo/ non low profile tires (65+ sidewall) tend to wear the edges of the tires anway. So max inflation or over-inflation will make them wear better. Low profile tires have stiffer sidewalls to make up for decreased air volume (load capacity) and are more prone to uneven wear due to over or under-inflation. Sidewalls are considerably stiffer than the span between them (tread).
Lo pro (225/55/17)inflation is more like a dighragm - sidewalls like surrounding frame, tread like the diaphragm.
Standard / Touring tires (225/70/15)inflate more like a balloon.
If anyone has seen the Modern Marvels episode on Disneyworld, their stunt team runs 80psi in their regular tires on the stunt vehicles. This reduces the contact patch for easier tire spinning and turns with the parking brake. Do what you will with that info.
Old 06-13-2011, 04:22 PM   #13 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
It was a while ago, but I remember 100psi, and it was at least in part to keep the rim off the ground when driving on two wheels.
Metrompg did some tests and the efficiency gains started tapering off around 40-50psi, so no reason to push it beyond that without your own data:
http://www.metrompg.com/posts/tire-p...resistance.htm
Old 06-13-2011, 04:31 PM   #14 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
When I lived in Colorado, the local high school shop teacher died inflating a split-rim truck tire without a safety cage.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Old 06-13-2011, 04:44 PM   #15 (permalink)
dcb
needs more cowbell
dcb's Avatar
yah, that stuff happens. i.e.
Autopsy: Man dies after over-inflated truck tire explodes - Chicago Breaking News
Truck tires are also many times more dangerous when they explode than a car tire given the increase in volume and psi (which equals much more stored energy). I think truck tires are like 52+ liters at 100+ PSI, and there's a lot of them on a truck, go figure.
