03-16-2018, 01:33 PM
#11 (permalink)
Slushbox ecomodder
Originally Posted by Daschicken
You could go for a set of 1st gen insight rims, and either swap over your stock(?) 175/65/14s or go for the famous re92 165/65/14s.
Mine is the sport model with 15in wheels, I’m not familiar with the re92 tire other than seeing it mentioned on people’s cars, is it a really low rolling resistance tire?
Also hey there GA friend!
03-16-2018, 02:24 PM
#12 (permalink)
Cyborg ECU
Actually, I want to correct my last post a little. The Fit auto's freeway RPMs, in top gear are 23% LOWER than a Fit manual would be. Your RPMs will also be significantly lower than the Fit manual in 4th gear (I did not calculate how much but maybe near 20% lower). Basically, the final drive gear is significantly shorter on the auto, but most of the auto's higher gears seem so much taller than on the manual that they way over-compensate. Highway cruising RPMs in your Fit should be significantly LOWER than a 2001-2005 Civic HX manual (like maybe 8% without accounting for wheel/tire size).
You could certainly work harder using a Fit manual trans and get better FE (check out the "PaleFit" on this site), but your auto is serving you pretty well.
Get the taller 195/65-16 wheel/tire combo I mentioned and your actual cruising RPMs on the freeway might match the legendary Civic VX fuel sipper.
I think I got it right this time.
12-12-2019, 03:10 PM
#13 (permalink)
Slushbox ecomodder
Back from the dead....
Insight wheels acquired, RE92s coming soon, do you think a ~700 lb heavier car will be too much for them?
12-12-2019, 05:57 PM
#14 (permalink)
Should be fine, just run higher than Insight stock pressure and they'll carry the load.
The Following 2 Users Say Thank You to Ecky For This Useful Post:
01-12-2020, 10:38 AM
#15 (permalink)
Slushbox ecomodder
Well I got the wheels installed still going first few tanks but it definitely seems to be helping I can feel quite a difference in rolling resistance
01-12-2020, 03:12 PM
#16 (permalink)
Moderator
Just noticed your username; I assume you're referencing the commercials from the Fit's US introduction ("THE FIT IS GO")? Post some pics of the Insight wheels on the Fit if you get a chance, I'm curious to see what they look like.
01-12-2020, 03:23 PM
#17 (permalink)
Slushbox ecomodder
That’s it!!! Haha
I tried to post a pic in the last post but it didn’t work excuse the dirt
The Following 3 Users Say Thank You to Fit_is_slo For This Useful Post:
01-13-2020, 02:04 PM
#18 (permalink)
Cyborg ECU
Rims look stock. I just wish they came in 15" sets.
01-13-2020, 03:01 PM
#19 (permalink)
I think that it is weird that tire places will happily sell you rims an inch or two taller, but when I tried to get a taller tire they refused, saying it wasn't safe.
It is safe with metal, not rubber?
01-16-2020, 09:13 PM
#20 (permalink)
Slushbox ecomodder
Seriously
I just buy them online and mount them myself but I have access to a shop so that helps
