Old 04-11-2013, 04:50 PM   #61 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
Originally Posted by volkov View Post
Hi!
To continue here
So, I've uploaded the 0.82, will install it into the car next weekend.
t looks ok, but allready have a question: how can I disable the alternating 999 MPG? I don't need it
Saidly I'm to "amator" to modify the code, but got some ideas:
-remaining KM, and alert below 80 Km (adding a beeper maybe? )
-time measure, all travel time, and all travel avg. speed
-remove the zeros!!! So display only one zero instand of 000.00
-display rmp?
Thanks!
ps:I'm stared learning Arduino
I'm working on a "Range" gauge for some time now, but it needs some work to finish. I don't mind zeros though. RPM's are displayed on a custom screen.
Interesting idea for time measurement and avg speed, so maybe someday... ;-)
Hopefully I'll publish all changes to the code I've made soon.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 04-12-2013, 04:14 AM   #62 (permalink)
volkov's Avatar
S2 E-RST - '86 Ford Escort RST Ghia
I have a little problem:
What the hell is that "P"?!
Old 04-12-2013, 04:21 AM   #63 (permalink)
AndrzejM's Avatar
I don't know TBH. It's the first time I see that mysterious "P"
Old 04-12-2013, 07:45 AM   #64 (permalink)
volkov's Avatar
Got the error (but dont know why..)
In "char bignumchars1[]" whenever theres is "255", I've got a "P" as you can see on the pic.
Old 04-12-2013, 07:53 AM   #65 (permalink)
AndrzejM's Avatar
Have you changed the code anyhow? Or is that clean copy of 0.82m published few post earlier?
Old 04-12-2013, 08:14 AM   #66 (permalink)
volkov's Avatar
No, not yet, first I've wanted to try the official code.
It looks like the 255 = 0xFF = all black character is a "P"...
Old 04-12-2013, 08:23 AM   #67 (permalink)
AndrzejM's Avatar
Start with changing the code in line
#define CFG_BIGFONT_TYPE 2 // 1=Original 2=Modified (adds about 20 bytes to code size)
To Big Font type 1 and see if problem still persist.
I think that's the issue of some specific characters set for your display. But can't be sure.
Old 04-12-2013, 12:15 PM   #68 (permalink)
volkov's Avatar
I've tried it with another LCD...
The code is ok, there's something with the LCD-s character set
Old 05-11-2013, 06:25 AM   #69 (permalink)
volkov's Avatar
I'm working on two Mpguino at the moment.
One is in the car (a little modified 0.82M) to set the values and calibration, almost done, I've done more than 250km and only got 100m difference on the VSS signal!!!
The fuel need another full refill, there the diff is 5-10%
The other setup is my table and I'm working on some mods.
-I've removed the first zeros
-add a temp sensor using a d18b20 one wire sensor
-add a screen saver: after time out, this screen appears
-add L/H in the L/100km page when the car is stopped, and display --- when the car is stoped and the engine is not running.
My other plan is to add RTC an display it on the screen saver screen
It's on it way from China
Old 05-13-2013, 03:04 AM   #70 (permalink)
AndrzejM's Avatar
What I love in MPGuino's project is that you can customize it any way you need/like/want.
I like the idea of screen saver maybe the logo of EM? ;-)
I don't need RTC because I have OEM clock
I've build in temp measurement code into my MPGuino using OEM engine's temp sensor (that one used for daschboard) because I couldn't find a good way to mount d18b20 within the coolant flow.
I need to make some more changes to my installation, because I want to build whole MPGuino into a instrument cluster, tghen check and calibrate the temp sensor and I'll be ready to publish everything here.
Volkov,
Will you post your changes to the code?
0.75, canada, canadian, kilometers, metric
just some humour for my Canadian freinds metroschultz The Lounge 6 12-23-2008 10:10 AM
News: Toyota unveils production version of Smart car competitor MetroMPG General Efficiency Discussion 8 09-06-2008 12:58 AM
Which Version of the Metro was most Fuel Efficient? Wayneburg General Efficiency Discussion 4 05-02-2008 07:10 PM
Canadian government caves in to automakers and kills auto efficiency rebate program MetroMPG General Efficiency Discussion 12 04-01-2008 06:19 PM
Canadian feds moving to block NEV's from public roads (also: hilarious ZENN vid) MetroMPG Fossil Fuel Free 11 12-20-2007 09:07 AM
