Old 06-19-2009, 01:12 PM   #1 (permalink)
Canceling out pumping losses of throttle governed engines
Tests have revealed that a vacuum on the crankcase is of negligible benefit of an otherwise stock engine.
At 7 in/hg of vacuum the seals were screaming bloody murder while drawing in air.
This thread can be considered null
Old 06-19-2009, 01:16 PM   #2 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
They do this with vacuum pumps for race cars... yes, vacuum in the block is a good thing, and it actually provides more than "marginally greater" ring seals.
I'm not entirely sure how much vacuum they use, but you can get belt-driven vacuum pumps from Summit Racing and Jegs for the purpose.
Old 06-19-2009, 02:12 PM   #3 (permalink)
Yaris - '07 Toyota Yaris Liftback
It is illegal in the US.
Old 06-19-2009, 02:13 PM   #4 (permalink)
Source?
Old 06-19-2009, 02:16 PM   #5 (permalink)
www.supersixmotorsports.com/pdf/PCVBypass.pdf
What exactly is a catch can and how does it benefit? [Archive] - The Australian 300zx Owners Association
Old 06-19-2009, 02:16 PM   #6 (permalink)
Oops ignore Australian one lol
Old 06-19-2009, 02:18 PM   #7 (permalink)
Try again - that article had to do with bypassing the PCV system. What the OP is talking about involves using the OEM PCV system with a higher vacuum - i.e. still feeding the crankcase vent into the intake system to be properly recirculated and burned.
Old 06-19-2009, 02:21 PM   #8 (permalink)
Ah ok. I thought he was bypassing it. My mistake.
Old 06-19-2009, 02:50 PM   #9 (permalink)
Civic 4 Life
KJSatz's Avatar
Civics Lesson - '08 Honda Civic LX
90 day: 40.53 mpg (US)
Honda's R18 has a system to help with that, right?
Old 06-19-2009, 04:21 PM   #10 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
Pulse and glide solves the problem.
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
Throttle sensitivity Formula413 EcoModding Central 13 05-29-2008 04:55 PM
Misc pumping losses questions tasdrouille General Efficiency Discussion 11 03-27-2008 08:14 PM
