03-31-2013, 09:40 PM
#321 (permalink)
The hatch door will be latched in the opening, and the rear doors will overlap at an angle and brace that plane.
04-01-2013, 02:02 PM
#322 (permalink)
Eco-ventor
I happend upon this episode of "How it's made" and it really reminded me of this thread:
http://www.youtube.com/watch?t=640&v=UFqw5MQ-4nA
Car factory of the (near) future perhaps?
The Following 2 Users Say Thank You to jakobnev For This Useful Post:
04-01-2013, 04:55 PM
#323 (permalink)
The foam in the airplane fuselage has a 10mm foam core? Wow, that is pretty thin.
04-03-2013, 01:50 AM
#324 (permalink)
IIRC Neil,
Each time the core thickness between the layers of composite doubles, the strength cubes. Just for an example, if the 10mm layup could handle 10 pounds of stress, then a 20mm thick layup should be able to handle a 1000 pounds(10 to the 3rd power) of stress. These are just made up numbers. No idea what these thicknesses can really handle. I do have a two foot long, twelve inch wide, 3/4" honeycomb core laminated with just glass that I can't even begin to bend by placing it over my knee.
JJ
04-03-2013, 09:16 AM
#325 (permalink)
Well, the 5" thick sides and rocker panels will be über strong?
By the way, I got a quote on the Smart ForTwo windshield, wiper system, and the vent bezel at the base of the windshield where the wiper arms pivot - and the total cost is about $820. Not bad, really. The next major expense with be the fiberglass.
Does anybody have suggestions on where to find a *manual* steering system?
04-03-2013, 10:03 AM
#326 (permalink)
Current bid is $150, selling tomorrow at noon.
Copart
I try to be helpful. I'm not an expert.
The Following User Says Thank You to sheepdog 44 For This Useful Post:
04-03-2013, 01:32 PM
#328 (permalink)
Originally Posted by jjackstone
IIRC Neil,
JJ
Hi Jack,
Actually for a "rectangle" shape in bending, when the thickness doubles, the strength goes up by four (T^2). This is for a material of solid section, i.e. one material, not a composite.
In the Machinery Handbook this is known as Z Section Modulus.
The theory is something like this:
1) When the section thickness doubles, there is twice as much material to take the load.
2) Since the thickness is now double, there is fiber strength that is twice as far from the neutral axis, and therefore twice as much strength based on that alone.
3) When you add 1) and 2) together, one ends up with four times the strength.
Now when talking composites, all this assumes that the "core" (foam) can handle the shear loads and/or compressive loads from the "skin" in the composite, without delaminating and/or buckling.
Composites modify the above listed Z-Section due to the single layer of glass on the thinner and thicker sections of foam, so the strength increase is not strictly defined by T^2 anymore. You can see that modeling composite structures is not an easy undertaking.
If one were talking about the torsional stiffness of a drive-shaft, then you are correct, that it goes up by the cube of the shaft diameter (D^3).
Hope this helps, Jim.
The Following 2 Users Say Thank You to 3-Wheeler For This Useful Post:
04-05-2013, 03:37 PM
#329 (permalink)
04-18-2013, 08:22 PM
#330 (permalink)
MPG Militia HMV-25E80+A
Neil, I'm thinking of coming down for the day and was wondering, since your place isn't too far from there, maybe a quick peek at your progress in person ? Maybe ? Pretty please with sugar on top ?
I looked on Google maps for the location and found it on the Center Common off Edgell Rd just North of Rt 9. If I take part of the "One Gallon Challenge" route, it's about 135 miles one way. If I cut across lower NH it's about 111 miles. Good chance for some practice .
