Old 03-08-2013, 06:54 AM   #11 (permalink)
Like a 2CV only newer
stargazerf3a's Avatar
Booboo - '06 Renault Clio 2 PH.3 LPG
90 day: 34.69 mpg (US)
Thank you that is really kind
I am aware that this sensor exist but not on late clios and kangoos there is only a fake sensor to cover that hole and does not have cables and such.
When i first tried to hook up the mpguino i took the service manual and searched the pin that vss sensor hooks up to the ecu and guest what, nothing there just a little rubber cap. So i've downloaded an newer version of the so called Renault dialogys and read about this feature they did to newer versions to reduce the amount of cables and connectors and that is true, half of the pins on the ecu are not used. So i has thinking that i can install a real sensor to the gear box that will be used only by the mpguino and consoluino (for cruise control maybe).
But i can not say it is cheap...
SPEED SPEEDO SENSOR RENAULT CLIO SPORT 182 172 2.0 16v LAGUNA MEGANE SCENIC 1.9 | eBay
Old 03-08-2013, 06:56 AM   #12 (permalink)
razor02097's Avatar
Tetanus - '95 Geo Tracker 4WD Base
90 day: 29.43 mpg (US)
300 - '82 Suzuki GS300 L
Last 3: 60.78 mpg (US)
Jeep - '98 Jeep XJ Cherokee Limited
90 day: 12.82 mpg (US)
Originally Posted by AndrzejM View Post
If you have access to oscilloscope you may see what's the issue there. But if switch is bouncing that may cause ECU to work incorrectly. Maybe you should take a closer look at your VSS switch.
It is just a simple reed switch. I don't think the ECU is as sensitive to SB as the MPGuino.
Project Avalon: E bike build
Old 03-08-2013, 06:59 AM   #13 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
You can always try a local junkyard
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 03-08-2013, 06:59 AM   #14 (permalink)
AndrzejM's Avatar
If you say so
Old 03-08-2013, 07:17 AM   #15 (permalink)
Of course tomorrow is a day off time for ecomodding
Old 03-08-2013, 07:20 AM   #16 (permalink)
Maybe mine is too cause abs sometimes feels like it locks the wheels a little when i am on a bumpy spot but that is just a reading from my butt-o-meter
I'll Try junk yard tomorrow that is a day off ecomodding day
Old 03-08-2013, 07:23 AM   #17 (permalink)
AndrzejM's Avatar
Good luck!
The Following User Says Thank You to AndrzejM For This Useful Post:
stargazerf3a (03-08-2013)
Old 03-11-2013, 07:29 AM   #18 (permalink)
razor02097's Avatar
I have tested this mod at 70ish. The speed reading is stable. There is no jumping or interference also it didn't mess any of the PPM or microsec/gallon settings up.
I would say mission accomplished
