Old 05-28-2010, 04:37 PM   #11 (permalink)
jackbauer's Avatar
Yep thats it Steve. I need one of these myself for my compound motor.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
The Following User Says Thank You to jackbauer For This Useful Post:
stevegaarder (05-30-2010)
Old 05-30-2010, 10:05 AM   #12 (permalink)
Thanks, Jack. The next question in my mind is how to handle regen. Do we just put a big diode across the MOSFETS to carry the current (assuming you can't rely on the intrinsic diode), or is there a better way?
Old 05-30-2010, 10:31 AM   #13 (permalink)
PaulH
MPaulHolmes's Avatar
The regen current is monitored by the current sensor. It can do -900 to 900amp. I think the intrinsic diode would be fine? The hardware overcurrent circuit would have to be modified a bit so as not to allow too much negative current either. Hey, you could do a PI loop to command a certain regen current I think. Maybe the gas pedal could be modified to allow for forward and backward current.
Fran was telling me that SEPEX motors and controllers can regen just about as well as A/C motors and controllers.
kits and boards
Old 05-31-2010, 04:05 PM   #14 (permalink)
jackbauer's Avatar
how goes progress on the boards?
www.evbmw.com
Old 05-31-2010, 04:34 PM   #15 (permalink)
PaulH
These boards? hahaha. The charger and bms is DONE! Just a wee bit more testing, and then I can finally do the gosh dang controller boards!
LiFePO4 bms with CAN. Good for 48 batteries. This is only 3 of the 6 modules:
0-200v input, 0-38amp (am getting a different inductor for higher currents), constant current, then constant voltage (or whatever friggen algorithm I want hahaha) LiFePO4 charger with CANbus and RS-232:
It's a race against the Chevy Volt! The controller is next!
kits and boards
Old 06-01-2010, 12:43 PM   #16 (permalink)
Originally Posted by MPaulHolmes View Post
The regen current is monitored by the current sensor. It can do -900 to 900amp. .
What sensor are you using? I want to buy one to make some measurements, and be able to use it with the controller later.
Touchy subject - Big Bang Theory (not the religious argument) robchalmers General Efficiency Discussion 11 08-26-2009 05:27 PM
Neil Young's Ideas to Save the Big 3 SuperTrooper The Lounge 1 11-22-2008 02:29 PM
Big Surprise: Fuel efficient cars are holding their value better than other cars SVOboy EcoModder Blog Discussion 2 09-19-2008 08:52 AM
Alternative to big motor and big $$$? WaxyChicken Fossil Fuel Free 16 01-28-2008 11:02 PM
