09-03-2020, 03:43 AM | #18 (permalink) |
If the Bugatti 100P didn't fly in the original 1939 configuration, there is another plane which made good use of similar drag reduction for aerodynamics and cooling: the P-51 Mustang.
The Mustang wing was a high lift configuration, as well as low drag. . . the Mustang in squadron service was not laminar to the same extent as the wind tunnel development models. Not one day in the past 34 years (the book was written in 74) has it performed in that manner for any or all of the reasons just given. So if it wasn't the laminar flow wing that gave it it's high speed and extensive range, what was it? The most prominent speed secret was the dramatic reduction of cooling drag. Placing the airscoop on the belly just in front of the rear edge of the wing removed it as far as was practicable from the turbulence of the prop and placed it in a high pressure zone which augmented air inflow. Tests in the wind tunnel with the initial flush mounted scoop were disappointing. There was so much turbulence that cooling was inadequate and some doubted that the belly scoop would work. The breakthrough was to space the scoop away from the surface of the belly out of the turbulent boundary layer of the fuselage. Further testing showed that spacing it further out would increase cooling but at a cost to overall drag. Various wind tunnel tests established the spacing at the current distance which represents the best compromise between spacing out from the turbulent flow of the fuselage, drag and airflow. With the flow into the scoop now smooth and relatively nonturbulent, the duct leading to the radiator/oil cooler/intercooler was carefully shaped to slow the air down (the duct shape moves from narrow to wide, in other words a plenum chamber) enough from the high external speeds to speeds through the heat exchangers that allowed the flow to extract maximum heat from the coolant. As the air passed through the radiators and became heated, it expanded. The duct shape aft of the radiator forced this heated and expanded air into a narrow passage which gave it considerable thrust as it exited the exhaust port. The exhaust port incorporated a movable hinged door that opened automatically depending on engine temperature to augment the airflow. The thrust realised from this "jet" of heated air was first postulated by a British aerodynamicist in 1935. The realization of thrust from suitably shaped air coolant passages is named after him and called the "Meredith Effect". Some have said that at certain altitudes and at a particular power setting the Meredith effect was strong enough to actually overcome all cooling drag; this is not regarded as being accurate by most aerodynamicists. It greatly contributed to overall efficiency of the cooling system but never equaled or overcame cooling drag. |
09-03-2020, 04:10 AM | #19 (permalink) |
The Mustang aircraft is interesting (and much quoted) but the low drag outcomes are of limited benefits to cars. But Porsche actually did achieve effectively zero cooling drag on one of their road cars: |
09-03-2020, 09:42 AM | #20 (permalink) |
1. Working by hand, with no wind tunnel or other aero instrument, it's pretty hard to reproduce the Porsche design.
2. However, the cooling improvement by leaving the rotation of the forward wheel to suck out the air from the intercooler bay has been tried and proven by thousands of people ever since 1999, when the Golf Mk4 platform with side intercooler became widespread. 3. It only works since a design quirk placed the intercooler very close to the wheel and separated from the engine bay with a plastic wall. Some insulative material on the wall and behind headlight in the upper engine bay, and the IC bay is thermally separated from engine bay entirely. 4. The car lacked some aero features which had become ubiquitous after 2004. Being designed during 1998-1999 crisis, when crude oil dropped to 10 USD/barrel, there was little incentive to cling to the smallest efficiency improvement. Official Cd had been 0.32 5. There is fitted from factory a partial grill block just behind the S badge, as visible here. Side upper grills may be covered on the inside in the same manner, but there is little benefit into doing so. Airflow for cooling is driven by the pressure differential across the radiator, more than by straight flow into the radiator bay. BEFORE / AFTER No deflectors before front wheels / Boat-prow deflectors before front wheels; Half undertray below engine / Full undertray from front lip to the rear end of the front axle Parachute-like shape of the rear bumper on the inside and rear axle exposed / Full undertray from rear axle well to the rear edge of the bumper; Nothing behind rear wheels / Boat tails behind rear wheels Big and ribbed muffler / Flat aerodynamic muffler Lower side of the intercooler open towards ground / Side undertrays left and right beside engine undertray Exhaust tunnel made a big bend before fuel tank / Flat aluminum plates around the exhaust bend (but not covering it) Sheet steel front control arms / Control arms plated over, like fish flippers parallel to ground Useless gaps in the front bumper, leading nowhere / All gaps which can't steer the airflow into intake or some radiators closed oveer Gaps in the bodywork / All gaps in the bodywork closed with rubber gaskets Audi has found out by experiment that smoothening the underbelly as much as possible may give a delta Cd around 0.024. If deflectors before front wheels really give a delta Cd of 0.01, this drops the overall Cd from 0.32 in the 0.28 range, which is actually very good for a daily-driven car. Last edited by Nautilus; 09-16-2020 at 08:45 AM.. |
Thread Tools | |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Electric vs. belt driven cooling fan | Gregte | EcoModding Central | 63 | 06-18-2013 06:42 AM |
Ethanol problems ? | Denis | DIY / How-to | 16 | 05-31-2011 05:14 PM |
2 problems with Scangauge II. Can you help? | regor | EcoModding Central | 11 | 10-29-2008 11:23 PM |
Winter weather mod problems.... | justpassntime | Aerodynamics | 7 | 08-05-2008 11:35 PM |
problems with EVs | igo | Fossil Fuel Free | 26 | 01-16-2008 12:15 PM |
