Old 03-27-2008, 06:09 PM   #11 (permalink)
"even heating on both sides would be critical"
-nope. Grab a heat gun and try it.
OK, thanks, I will.
But, wouldn't just the heated side give, leaving the unheated side to resist the shape change? (this for blister making)
Old 03-27-2008, 08:53 PM   #12 (permalink)
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Toyota Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Toyota Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
Frank, you seem to be he BMOC,
lets see some of your fabrication skills with this stuff..
Old 03-27-2008, 09:05 PM   #13 (permalink)
To make a curve in Coroplast, because of the structure of it, we basically need to collapse/distort the "corrugations" and either stretch the convex side and shrink or collapse the concave side. So it's not really like forming single thickness sheet, which is practically all stretching. I have found most success by heating the concave side. I would love to try vac forming it but no longer have access to a vac former. For years I made prototype parts on a vac former and it was fun.
You da man, Frank.
May I pester you with questions about vacuum forming?
Vacuum forming is used in all sorts of consumer products, for blister packaging so you can see the product contained in the package. What kinds of clear, smooth plastic work well for this? Acetate sheet? Acrylic? Lexan?
What is easiest to work with?
Cheapest?
Have you seen the thermoforming and vacuum forming videos on You Tube? From those, it seems that home made vacuum forming machines could be cheap and easy. Your thoughts?
Old 03-27-2008, 11:14 PM   #14 (permalink)
EcoModding Minded
Chris D.'s Avatar
you can do it the old fashioned way and 35mm and have the pictures put on a disk at the same plafe for a few bucks more..
You have so many responces to tech stuff, your car must be amazing
Old 03-27-2008, 11:45 PM   #15 (permalink)
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
i tried forming plexiglass once and i had more even heating using quartz work lights than a heat gun. it seemed to penetrate inside the plastic, rather than just surface. haven't tried coroplast they gathered up all the big political signs before i had a chance.
crx coroplast belly pan finished! paulwelkins EcoModding Central 28 05-15-2015 05:24 AM
Where did you buy Coroplast? tjts1 EcoModding Central 28 11-18-2009 01:12 AM
A Question LostCause The Lounge 5 04-06-2009 11:01 PM
e-bike power pack question Lazarus Alternative Transportation 13 02-21-2008 11:10 PM
newb intro and question about civic hb vx reformed Introductions 9 01-29-2008 11:28 PM
