Old 07-13-2008, 02:18 PM   #1 (permalink)
CRX HF Vtec-e
CRvX HF - '90 Honda CRX HF
D15Z1 Engine surging, help needed...
Got the d15z1 full swapped into my crx. Engine started up no problem, no cels. Engine idles great, revs fine, but has a hesitation/surging problem around ~1500rpm at part throttle (think trying to take off in first gear). Have gone through all the vacuum diagrams and everything is hooked up right. Any ideas?
Old 07-13-2008, 02:23 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Vacuum leak? Where's it idling?
Old 07-13-2008, 02:25 PM   #3 (permalink)
CRX HF Vtec-e
idling at 600rpm, checked vacuum equals 15psi at idle, timing is set right on as well.
Old 07-13-2008, 02:54 PM   #4 (permalink)
Dartmouth 2010
SVOboy's Avatar
Can you monitor the afrs and see what they're doing around the time of the stumble?
Old 07-13-2008, 03:12 PM   #5 (permalink)
CRX HF Vtec-e
Not really, I can monitor the voltage on the o2 sensor, but thats about it without a afr guage
Old 07-13-2008, 04:32 PM   #6 (permalink)
vtec-e's Avatar
De Yaris - '04 toyota yaris T2
90 day: 69.55 mpg (US)
Is it the lean burn? My civic does that when i drive gently and hesitates when i bring on the throttle a little. I heard its the lean burn being weak and it takes the ecu a second to come out of lean burn. I dunno. Me heads fried, the hatchets are gone to bed and i'm skulling a few cans to settle me nerves!!
ollie
Old 07-13-2008, 04:46 PM   #7 (permalink)
Dartmouth 2010
SVOboy's Avatar
^ I'm also thinking it might be lean-burn. Monitoring the volts should be enough, since you can see the change to tell whether you're in lean burn or not.
Old 07-13-2008, 09:37 PM   #8 (permalink)
CRX HF Vtec-e
Ok, so i measured the voltage across vs+/vs- and ip+/ip-. I also tested a few more things. the engine runs fine at part throttle up until 1450rpm, then the engine starts surging at any speed at part throttle, but runs fine at full throttle. So, that being said here's what I came up with:
vs+ idle +.5v, drops to +.39v while surging
ip+ idle pretty steady at +.47-.5v with the occasional drop to 0v. at 1300rpm it picks up to +.65v with the occasional drop to 0v. while surging it goes back and forth from +1.07v to +.7v
Old 07-14-2008, 12:43 PM   #9 (permalink)
vtec-e's Avatar
ok, i'm lost!
Old 07-14-2008, 12:45 PM   #10 (permalink)
Dartmouth 2010
SVOboy's Avatar
Originally Posted by vtec-e View Post
ok, i'm lost!
Yeah, me too. I wonder if the o2 is just dead and being funky. Try unplugging it and seeing if it still does it.
How to smoothly bump start / clutch start an engine MetroMPG Hypermiling / EcoDriver's Ed 76 03-22-2014 07:52 AM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 08:38 AM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
