Old 09-17-2011, 08:47 AM   #511 (permalink)
Originally Posted by tumnasgt View Post
People that drive with their rear fog lights on.
I agree, they're a right pain.
Old 09-19-2011, 06:19 AM   #512 (permalink)
The PRC.
Today'a annoyance - we have teams in offices - one for projects, one for development. I'm in the latter one and alone today.
So guess what, when you try and call my phone and its engaged its highly unlikely I will be available answer the other one you called because you got the busy tone on the first, even if you call back every 30 seconds.
Of course the building is only 200 feet long so you could walk round instead.
But if you do then don't be too surprised if you are ignored because
I'M ON THE B***DY PHONE!
Old 09-19-2011, 07:19 AM   #513 (permalink)
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
I'm doing a time management course in work..
Its laughable, but its killed 1/2 a day so far!
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
Old 09-23-2011, 03:34 AM   #514 (permalink)
The PRC.
I have started a cold, which means I will have it for the weekend.
Old 09-23-2011, 07:36 AM   #515 (permalink)
Team m8
Surekly thats good?
Chance to lie on the couch, with the duvet, requesting that you be fed chicken soup at regular intervals, and that beer is "medicinal"
and dont forget "the limp"
Old 09-23-2011, 01:27 PM   #516 (permalink)
wdb
lurker's apprentice
PlainJane - '12 Toyota Tacoma Base 4WD Access Cab
90 day: 20.98 mpg (US)
Originally Posted by 320touring View Post
Surekly thats good?
I find that Top Gear episodes go very well with beer, medicinally speaking. **cough** I may be coming down with something myself.
Back on the annoyance topic. I used to work for a PHB whose idea of scheduling was simple: leave everything until the last possible moment, then:
  • declare an emergency
  • demand that your minions do the work you failed to do
  • demand that the work be performed within the next hour
Now in a new position, I thought I was rid of him. But nnnnoooooooo. My new team sometimes relies on his group for tasks. He is still up to the same tricks, only now instead of waiting for the emergency declaration, I anticipate his inaction and do his work for him in a more timely manner.
It still grates at me.
Old 09-23-2011, 10:42 PM   #517 (permalink)
larrybuck's Avatar
Location: sw Washington (state), a little north of Vancouver
I just got home from a one week road trip.
Unfortunately, I had an evil tire w a horrible wobble which wore me down on the last day of the trip until I could do something about it.
So yesterday, I go to my local nationally known tire shop chain, get the LOSER tire identified, and have it replaced.
The person servicing my car was younger, but I know he works there daily, and has been there at least two yrs. or so.
I get home, which thankfully is only 2-3 miles from tire shop.
I go to adjust their 32psi to my 41-42, when I see the valve stem is not at all even in it's 3 inch window pane in the hubcap, but it's bent over, pinched and pinned behind the next section of hubcap!
On my car, (this is the CRX) all four lugnuts must be totally removed for the hubcap to move an inch anywhere!
I do now have a fine floor jack, and have used a star wrench for yrs., so my fix was no big deal, but a non car person would never have noticed anything, until the stem would have eventually been cut off, leaving a miserable roadside event inevidable!
It just makes you wonder!
At least a half dozen times in my life; I've had to fix at home some boner that a place charging me mucho bucks an hr., that at supposed to be professionals; just blow it!!!
Some of you must have your horror stories as well!
Unbelievable!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 09-23-2011, 10:43 PM   #518 (permalink)
larrybuck's Avatar
Old 09-23-2011, 11:15 PM   #519 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Thanks KC!
Here's a special THANKS to the Streets and/or Water Department(s) of Kansas City, Missouri -- for leaving a water access plate with the pavement cut largely, sharply, and deep around it (to do whatever the heck), AND LEFT IT OPEN with no cover or hot patch.
So I drive along, see it, try to miss it, and KA-BLAMM! No such luck. It knocked the TSX way out of alignment and luckily didn't cut the tire or bend the rim. I'm really working this car's FE to 32mpg (up from 26) on this tank and now the alignment is making it harder to track and maintain momentum. Grr. THANKS!
Meh, it needs new rear tires and alignment anyway. I need to shop for low RRs, preferably Michelins (not having luck with other brands).
So, if you're driving up Holmes Rd. North from I-435 before Bannister -- LOOK OUT!
Postscript: Normally you can submit a claim to State and Local municipalities to pay for damages. Kansas City? Good luck. If it was on a State Highway or Interstate, MODOT has a great record of getting folks compensated. A dishonorable mention to city of Belton, MO, for leaving a construction project unprotected and taking out 2 tires, motor mountS, and alignment 5 years ago. Pictures were taken, etc, but no compensation. THANKS!
So THANKS to those responsbily for the crappy road conditions -- you know who you are
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 09-24-2011, 05:23 AM   #520 (permalink)
The PRC.
Surekly thats good?
Limp what
I ended up going home ill after a bad reaction to the cold remedy I used - it was a strong one I got in Spain earlier this year. Have now thrown the rest out...
