Old 01-25-2012, 07:20 AM   #571 (permalink)
The PRC.
SQL Server Reporting Services - you are cr@p.
Old 02-08-2012, 02:47 AM   #572 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
I just read that with the cold spell here, Warsaw's city busses are left idling all night. The drivers aren't happy about it, and the people who live next to the shop have had enough of the noise and emissions, even the maker of the busses is surprised, but the shop's officials say everything is under control. According to one side of the conflict, the busses aren't kept in tip-top working order and might not start after a cold night. If a bus can't start and doesn't do its rounds then the shop has to pay a fine. Supposedly the extra fuel cost is less than that fine.
Some numbers: Each bus uses 3 liters per hour when idling, and idles for at least 5 hours per night. This bus company has 1100 busses, but it's not clear whether all of those busses idle through the night or only the busses at that one shop.
Old 02-08-2012, 03:29 AM   #573 (permalink)
You'd think it would pay, if not to fit/have/use plug-in heaters, to have a guy run them for a while (5 minutes? 10?) then shut down for- oh- three or four hours, then run 'em a bit more. He could go right down the line and do that all night.
Old 02-08-2012, 03:36 AM   #574 (permalink)
tumnasgt's Avatar
The Charger - '15 BMW i3
You'd think block heaters would be cheaper than running the engines overnight.
~$25US/night * 14 nights a year (?) * 10 years = $3500US. I don't know what a block heater for a bus costs, but it's gotta be cheaper than $3500.
Old 02-08-2012, 04:14 AM   #575 (permalink)
aero guerrilla
Piwoslaw's Avatar
The bus drivers proposed investing in engine warmers, for example electric, but the higher-ups know better, don't they?
A block heater could be used to improve start-up fuel consumption year-round...
Old 02-15-2012, 10:56 PM   #576 (permalink)
n00b.... sortof..
d0sitmatr's Avatar
silver fire - '03 Mazda Protege5
90 day: 32.52 mpg (US)
working/rebuilding on my computers...
uhg...
~Mike
Old 02-16-2012, 12:37 AM   #577 (permalink)
larrybuck's Avatar
Location: sw Washington (state), a little north of Vancouver
I like a lot of things that VW, does but the old combo lugnut/stud in 1 can be a pain!
At night, w a flat; you'd just about have to hold a flashlight in your mouth, hold the tire/wheel up w one hand in just the right spot, to start the nut/stud w your other.
Pretty awkward, I'd say! Nothing against women, but even a very competent one;
could you imagine her struggling in that night scene w this; and the happy remarks
one would hear about it from her later???
06 Chev MonteC JG#24tribute car 30mpg 00 Honda Insight 63MPG 98 Buick Park Ave3.8 33MPG 89 Toyota Corolla wag 53MPG so far 81 VW Rabbit diesel pu 50MPG+ 80 Mercedes 240D stick 30-ish 90 vette 6-speed,29ish 07 Honda ST1300 55MPG 83 Honda 650 GL 64MPG 19 Suzuki dr200 88MPG23 HondaGrom?+Tow K10D Sub 26mpg NEVER,NEVER GIVE UP!
PUMP THOSE TIRES UP!
DRIVE IN YOUR SOCKS FOR SENSITIVITY!!!!!!!!!!!!!!!
SLOW DOWN AND SMOOTH UP!!!!!!!!!!!!!!!!!!!!!!!!!!!!![SIGPIC]
Old 02-16-2012, 03:57 AM   #578 (permalink)
The PRC.
I find a good rebuild from scratch every now and again quite theraputic - for me and the machine
At night, w a flat; you'd just about have to hold a flashlight in your mouth, hold the tire/wheel up w one hand in just the right spot, to start the nut/stud w your other...
+1 - its not just VW, they all seem like that these days. What was wrong with the old arrangement ?
Old 02-16-2012, 07:21 AM   #579 (permalink)
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
bmw toolkits have a locator that you can slot in to line up the wheel, then put in one of the bolts..easy
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
Old 02-16-2012, 07:28 AM   #580 (permalink)
The PRC.
Yeah, but it comes with a BMW attached....
...good idea though
