Old 05-15-2012, 01:48 PM   #1 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Disabling intake and exhaust valves (going to 8 valves in a 16-v head)
My original plan was to install a CRX HF camshaft along with the roller rocker arms in my 16-valve Civic Wagon. The HF torque peak is something like 2500 RPM lower than my engine. The HF has only 8 valves, but it's pretty clear that the head is very similar to the 16v head. There are blank spaces where the valves would be.
Unfortunately (and surprisingly) the HF cam has larger lobes that hit the 16v head, so I was unable to install the HF cam. So what I ended up doing was just using the spacers that are used on the HF in place of the missing rocker arms.
So far I like it. It's more responsive and torquey at the very low RPM I usually drive at. I kept overshooting my 2000 RPM shift point. But it will not make it to redline in second gear anymore. It's probably not an ideal setup, since the camshaft wants to make midrange power and the valves won't let it. I'm hoping for an increase in MPG, time will tell.
Not surprisingly, the exhaust is much quieter now.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following 6 Users Say Thank You to Gasoline Fumes For This Useful Post:
Christ (05-15-2012), kurzer (06-05-2012), renault_megane_dci (02-28-2013), robertwb70 (06-04-2012), t vago (05-15-2012), ultimx (06-05-2012)
Old 05-15-2012, 02:30 PM   #2 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Interesting! Looking forward to seeing your results.
Old 05-15-2012, 03:38 PM   #3 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Cool! You mentioned this at GGP. Nice to see it come to fruition.
More torque down low is usually a good thing for the light-footed.
Subscribed for updates.
Old 05-15-2012, 09:35 PM   #4 (permalink)
good idea. i'll be curious how it works out!
Old 05-15-2012, 10:42 PM   #5 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
I was really hoping to use the HF cam too. Or "diesel cam" as I had been calling it.
It seems to make the most difference at part throttle and at low RPM. I probably lost 20-30 HP at the top end, but I wasn't using it anyway.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
Old 05-15-2012, 10:57 PM   #6 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Why not just swap the HF head on? It doesn't take long, and you get the proper intake manifold to deal with the required higher air velocity at lower speeds, as well as slightly larger valves than the 16V heads have, which allow better flow at low RPM.
And you can use the HF cam. You can also use your stock electronics to run that head, as long as you only use the head, and don't try to incorporate the recirc valve on the intake manifold.
I also have a complete HF swap I'm selling, if that's something you're interested in. It's currently in Johnson City at a buddy's house.
Old 05-15-2012, 11:12 PM   #7 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
I would swap the whole head, but the one at the junkyard has been sitting for at least a year with no valve cover or hood. Might be OK, the cam was fine. But it's missing the injectors and possibly other parts. I saw your ad and I'd buy your swap if this poor Wagon wasn't so rusty. I'd look for a better shell, but like Darin, I'm suffering from TMP.
I'm tempted to swap in the HF trans, but I'm scared of gearing that tall in a heavier Wagon that I use like a truck. I'm often wishing for a shorter first gear.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
Old 05-15-2012, 11:18 PM   #8 (permalink)
The first gear is the same, the final changes it a bit. With the added low-end torque of the HF swap, you'd probably be net about the same.
One problem I had with the HF's gearing was that, even in my +100 HP sedan (~120HP at that time, IIRC), I couldn't pull anything except 3rd gear up long hills, and accelerating past 60 or so was just wishing in a bucket (on those hills). I was also running 205/40ZR16 street performance tires and hadn't done much else to the car at that point.
For the record, I'd entertain trades for the swap as well, if you know anyone that's interested in it.
Old 05-15-2012, 11:45 PM   #9 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
The HF 3rd gear is slightly taller than my current 5th gear! First gear with the HF final drive is about halfway between my 1st and 2nd gears. I can take off in 2nd gear now on flat ground, but it would kill my clutch on a hill. I might try the HF trans, I keep thinking about it.
I don't have much to offer in trade. Have any use for a Chevy 350?
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
Old 05-16-2012, 12:07 AM   #10 (permalink)
I had no idea that you could run a 4-valve head with a 2-valve cam! I'm very interested!
