Old 01-27-2023, 02:51 AM   #11 (permalink)
VW GOLF - '96 Volkwagen Golf MK3 GL
90 day: 50.21 mpg (US)
Commute scoot - '95 Suzuki AE50 Style
Last 3: 70.4 mpg (US)
The German - '99 Mercedes W202 C200 Classic
90 day: 27.65 mpg (US)
This is a relatively simple arduino project, but something outside the range of the standard hobby sensors (Sharp IR and HC 10x ultrasonic?) - 60cm and 4m respectively.
Maybe some kind of inexpensive laser time of flight sensor could be hooked up to a speed sensor.
Will you recoup money spent on mods in fuel saved? see my spreadsheets here
Old 01-27-2023, 03:27 PM   #12 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
So are there any radar sensors with 100m range available in the amateur hobbyist price range?
Or at all?
Old 01-27-2023, 03:38 PM   #13 (permalink)
Mazda CX-5 - '17 Mazda CX-5 Touring
90 day: 26.68 mpg (US)
Looks like $400 used on Ebay. You need 2. Then you need vehicle speed sensor, a controller to make sense of all that and output a throttle control signal.
Old 03-11-2023, 03:40 PM   #14 (permalink)
The three-second rule is a good one for safety, flexibility and legality. It's easy to employ without having to take your eyes off the road. We do it in my area of the world by saying "one Mississippi" for each second of time being gauged.
I used to use a vacuum gauge installed on the intake manifold to see the beneficial effects of following a big truck etc. Nowadays, I have a ScanGauge with instantaneous MPG readings to do the same.
One of the big things I keep in mind when following a vehicle in traffic is that rear-end accidents can be expensive and even lethal, and that the guy who does the rear-ending is almost invariably at fault.
Old 03-12-2023, 09:31 PM   #15 (permalink)
I use the 3 sec. rule as reaction time is critical. I have no way of knowing what the vehicle and its driver will do next. I would not want someone drafting me with out radio contact to coordinate actions. Just how close is close enough to gain any advantage?
Old 03-12-2023, 11:02 PM   #16 (permalink)
According to aerohead:
"We're deeply sorry." -- Pfizer
