Old 12-14-2008, 01:10 AM   #11 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Ew... toe shots.
Seriously, you didn't HAVE to do half the work you did there to get those pieces off.
The trim piece on the fender comes off easily without removing the fender, and you can remove the entire bumper, cover and all, with (usually) two bolts.
If you remove the bumper lenses from the car, set them aside, and look inside, you can use a 3/8" Drive 6" extension and a 10mm ratchet to disconnect the bumper from the car completely, then remove those small Philips head screws on either side of the cover, (in the fender wells) and it will literally fall off the car, where you can have better access to all those screws that hold the cover to the bumper.
For the fender trim bar, remove a few of the fasteners from the inner fender on the back side, pull it away, and use any small pair of pliers to engage those two clips, while pulling at it from the visible side or prying with something small and not-scratchy. (I use plastic silverware a lot on cars.)
Also, your corner lenses should NOT have a screw visible in them at all. That was one of the aesthetic changes to the 90-91 Civic/CR-X models, they shaved the fasteners from the corner lenses. Someone must have put it there of their own accord.
There is absolutely no difference in the fenders of the 90-91 vs. the 88-89 cars, other than the plastic screw receptacles in the fenders of the 88-89 models were filled with strut receptacles for the 90-91 model years, while the lenses themselves were given tabs that coincided with the old-style's screw location that engaged those strut receptacles to prevent lateral movement of the lens/housing assembly.
Also, if you don't want to paint all that trim, and you still want it to be shiny black, Mother's makes a great polish for it, and peanut butter or peanut oil will actually bring back the OEM appearance of the rubber bits. (Not the plastic though.)
Other than all that, good work on the walk-through, and hope to see more detailed posts in the future.
Old 12-15-2008, 02:46 PM   #12 (permalink)
Originally Posted by SVOboy View Post
I am also confused.
It's simple--"femina" is a spammer. S/He probably has links to some sales-type website in his/her profile, in an attempt to drive up the Google rating of said site. It may even be a site that has something to do with paint...
-soD
Old 12-15-2008, 10:27 PM   #13 (permalink)
Giant Moving Eco-Wall
DifferentPointofView's Avatar
The Jeep! - '95 Jeep Grand Cherokee ZJ Laredo
90 day: 23.75 mpg (US)
The Caliber - '07 Dodge Caliber R/T
90 day: 30.6 mpg (US)
The 'Scort - '98 Ford Escort LX
oh, nice CRX SVO. How long have you had it? I've never seen one in such good condition before (besides the restored ones).
Yea.. I drive a Jeep and I'm on a fuel economy site, but you just wouldn't understand... "It's a Jeep thing!" *Jeep Wave*
Did I Use Too Many Abbreviations? Here's The Abbreviations List
Old 12-15-2008, 10:43 PM   #14 (permalink)
bluesfan's Avatar
The Bluesmobile - '08 Mazda B2300 2WD
90 day: 22.62 mpg (US)
Originally Posted by Christ View Post
...your corner lenses should NOT have a screw visible in them at all. That was one of the aesthetic changes to the 90-91 Civic/CR-X models, they shaved the fasteners from the corner lenses. Someone must have put it there of their own accord.
Honda humor?
P.S. Many happy returns on your upcoming birthday
In reverent quest of the last mpg...
Old 12-15-2008, 10:46 PM   #15 (permalink)
Originally Posted by bluesfan View Post
Honda humor?
GAH!.. someone noticed the b-day. I'm gonna melt now.
The "accord comment" was actually completely unintentional... I wish I had noticed it when I posted it... I could have made it a prelude for another quip.
