Old 12-03-2009, 03:03 AM   #21 (permalink)
Originally Posted by Rokeby View Post
Another way to do this:
Jeep Rubicon Express Hand Throttle Installation
The hand throttle kit goes for ~$30:
RE1000 - HAND THROTTLE - Rubicon Express
Parts might be cheaper at your local bike shop.
They are located nearby me, cool people.
Old 04-30-2011, 06:02 PM   #22 (permalink)
in my country a cruise control system must deativate when the brake is pressed or its illegal
ive been thinking of attaching a magnetic clutch to the side of the throttle arm
which locks when powered
they are like $20 on ebay
add an on off switch to activate it and a cut switch on a relay under the brake
seems simple enough
ill give it a shot and take photos if it works
Old 05-01-2011, 12:21 PM   #23 (permalink)
Has anyone heard of electronic throttle lock? I've read about it, but cannot find it anywhere. I'm getting parts ready to retrofit cruise control, but was wondering about throttle lock as well.
Old 05-01-2011, 03:50 PM   #24 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
seems simple enough
No, you just do it the same as dcb, and don't refer to it as cruise control at MOT/inspection time. Its a throttle lock for your exhaust gas generator, which needs to run at higher than idle for extended periods...
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
Scangauge II vs cruise control rjacob Instrumentation 10 06-02-2011 02:36 PM
Throttle locking the cruise control? Xringer EcoModding Central 6 12-26-2008 10:29 AM
Reprogramming cruise control. TKWPrime EcoModding Central 7 09-22-2008 04:49 PM
Cruise control mod idea rjacob DIY / How-to 18 07-29-2008 11:27 PM
