Old 03-24-2010, 11:44 AM   #281 (permalink)
AC-DC enthusiast
mrbigh's Avatar
Dual-PWR PHEV - '04 Toyota Prius
Kopper - '79 Bradley Bradley GT-II
Originally Posted by apowers View Post
I did not change anything. It was the chip from my motor controller with the software from last summer. I was thinking maybe it could control the voltage and other things. I don't write code I'm not sure that I could load someone else's code.
Alvin
Can you repost the pictures, nothing is showing.
Thanks
Prius Absolutum Dominium . ..........KOPPER
PHEV conversion since Dec 2006.. . .... .Future EV
. . . . . . . .CALCars # 27. . . . . . . . . . ..on the works now !!
Old 03-24-2010, 08:34 PM   #282 (permalink)
apowers's Avatar
Are the pictures showing now?
Alvin
Old 03-25-2010, 11:26 AM   #283 (permalink)
AC-DC enthusiast
mrbigh's Avatar
Alvin
Nope.
There are two ways to have pictures showing in this type of forums that I know.
Including a link of the picture from a web host server like "photobucket" or others similar services and; uploading the pictures to this forum from your computer.
This will show like a thumbnail to full allowable size upon clicking on them.
Old 03-25-2010, 08:08 PM   #284 (permalink)
apowers's Avatar
I can see the pictures. Can anyone else see them?
Sorry
Alvin
Old 03-25-2010, 10:21 PM   #285 (permalink)
EVVette - '71 Chevy Corvette Coupe
The problem with your pictures is there not an actual link to a picture. The Kodak gallery shows the pictures more as a web page and not an image...
You wont be able to get the kodak gallery images to show up.
You should either use the attach image feature to add pictures, or just include a link only.
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
Old 03-25-2010, 11:23 PM   #286 (permalink)
apowers's Avatar
I hope this works.
Old 03-26-2010, 07:30 AM   #287 (permalink)
It works!!
So the pot adjusts charge current and the timer adjusts time at that current?
When the timer ends, what does it shut off?
-Adam
Old 03-26-2010, 08:47 AM   #288 (permalink)
apowers's Avatar
The ac power to the inductor and the fan are on the timer.
Alvin
Old 03-26-2010, 10:53 AM   #289 (permalink)
I can't upload files of the charger I designed. When I browse to the file, and click on it, I get "Wrong type". These are Adobe. I don't know squate about computers. if someone posts a spare e-mail address, I can send them as an attachment. I sent them to Paul but he's away. Mayby Jack Bauer would like to see them. The charger is 6 KW, pfc corrected, with a novel soft-start circuit that wastes no power, using a .39$ common resistor. The input is 50-60 Hz, 85-265v.It also automaticaly draws no more than 15 A from 120v, and 30 A from 230v. It outputs 165V and has a low-level input from a BMS or a charge controller PCB to control the charge rate. The input is open or 2.249v equals 165V and 5v equals 121V. These can be scaled. It is therefor, not a complete charger. The control PCB uses only one IC, an opto, and a TO-92. There is a HF iso trans. All ferrite, including trans. design drawings. I have the Epcos cores(E70/33/32), but can't find bobbins anywhere in the US or the Continent. Jack Bauer: did you buy bobbins in Ireland? Kindest regards to all.
Old 03-26-2010, 10:57 AM   #290 (permalink)
I would be Very interrested in seeing these and would get them up on the site for you.
You can send them to me at : Adamj12b AT gmail DOT com ( replace AT with @ and DOT with .) Sorry its a little cryptic, Spam bots look for email address in the correct format.
-Adam
ev charger
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1041 07-28-2014 09:19 AM
Any interest in developing an open source fuel economy gauge/computer? MetroMPG OpenGauge / MPGuino FE computer 182 06-25-2010 07:00 AM
Open source PCB design dcb OpenGauge / MPGuino FE computer 39 04-25-2010 09:18 PM
Open Source electric conversion information bennelson Fossil Fuel Free 8 02-14-2009 11:23 AM
Open Source LEV Controller FrankG Alternative Transportation 1 03-24-2008 03:10 AM
