Old 07-11-2010, 06:02 AM   #1 (permalink)
Delivery 'Boy - '86 Suzuki Mighty Boy
90 day: 37.15 mpg (US)
SkipSwift - '13 Suzuki Swift GL
90 day: 35.44 mpg (US)
DIY - Prototyping undertrays
Instructables Link
Just thought I should blow my own trumpet. It should prove useful.
Next month (if it all works out and the result is positive) I'll do ABS ones, so that they look good...
The Following User Says Thank You to BLSTIC For This Useful Post:
Nevyn (07-16-2010)
Old 07-14-2010, 07:45 PM   #2 (permalink)
Blow stuff up
phunky.buddha's Avatar
S2000 - '03 Honda S2000
90 day: 24.42 mpg (US)
Very nice!
I think your "reasons" for the OEMs not doing it aren't quite right though- I would put the reason at not being able to service the car easily. That IS how the dealerships make their money- working on the cars after the sale.
Old 07-15-2010, 12:18 PM   #3 (permalink)
No, my undertray doesn't extend past the bottom of the radiator, it covers no maintainance items except possibly the air-con gas reservior. The rear one covers only the fuel tank (as stated in the instructable).
Incedentally it appears to work. The pair have apparently dropped 0.3l/100km (according to factory display), and the car has noticably less wind noise....
Old 07-15-2010, 03:33 PM   #4 (permalink)
Blow stuff up
Ah, ok. I was thinking that your tray covered the entire length of the car.
Intercrew Auto Salon
Old 07-16-2010, 01:30 AM   #5 (permalink)
bike4miles's Avatar
Even with a full tray they can always add access panels. That is what I intend do do.
Old 08-08-2010, 05:37 AM   #6 (permalink)
XJguy's Avatar
You have to understand that while you drive your car on the road at a nice pace with abundant air and usually at short distances, when manufacturers make a car, they engineer them to survive extreme conditions, including 100+ degree weather with full load capacity with the AC on and in stop and go traffic. In order for a car to function with an undertray and survive this and more it would take much more engineering, exotic materials, and money. This is why cars do not come with undertrays, save for the ones that cost north of $100k. I saw a whole story with car engineers about the matter several yeas ago. Heat and longevity are the problems.
Old 08-08-2010, 05:52 AM   #7 (permalink)
I did the testing. Saved 0.4l/100km...
I also tested the cooling system performance with and without the trays, no difference. The only downside is that anything that goes through the grill opening either goes through the radiator or gets stuck. There is no more option for birds to fall out under the car, they just stay there and rot if I don't know they are there
Old 08-08-2010, 05:55 AM   #8 (permalink)
Oh I should have mentioned my driving during testing covered a very wide range. Hot, cold, wet, dry, city and country (and any combination of those). And a couple of mountain ranges too.
And just for good measure, some 150kph cruising in 35*c weather...
Old 08-08-2010, 06:01 AM   #9 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
the 2011 Audi A8 has a factory underpanel
And my 02 Infiniti Q45 has factory under panel for the first 38 inches.....just at the transmission.
also angled deflectors infront of the front tires.
there is a service panel that opens to reach the oil filter and the nut.
Had I not installed a full body kit which lowered the profile 2 inchs and created a gap to the panel, I would not have made a new one.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 08-08-2010, 01:42 PM   #10 (permalink)
XJguy's Avatar
Most new cars are quite smooth on the underside and have at least partial undertrays...you can even fit one to most older cars as well. I was referring to complete belly pans like those found on the Mercedes SLR.
The Following User Says Thank You to XJguy For This Useful Post:
MrMiata (11-13-2010)
DIY: OEM VX PCV and Info TomO DIY / How-to 4 04-02-2011 09:38 AM
AC vs DC for DIY MazdaMatt Fossil Fuel Free 15 03-06-2009 09:33 AM
Three Dirt Cheap DIY Electric Cars - Part 4 SVOboy EcoModder Blog Discussion 3 12-12-2008 08:14 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
Three Dirt Cheap DIY Electric Cars - Part 3 SVOboy EcoModder Blog Discussion 0 12-05-2008 10:30 PM
