Old 04-20-2008, 07:59 PM   #21 (permalink)
Liberti
LostCause's Avatar
Thunderbird - '96 Ford Thunderbird
90 day: 27.75 mpg (US)
If you are only worried about overheating while idling, I'd just rig up a water sprayer to inject mist on the cylinders. If there is any fear of shock cooling, you could take the slightly less efficient route and spray mist into the cooling intake air.
This would work especially well in dry, hot climates common in the southwest. It would probably work, albeit less efficiently, elsewhere in the United States.
- LostCause
Old 04-21-2008, 06:33 AM   #22 (permalink)
Funny's Avatar
Eco-Fit - '13 Honda Fit Base
90 day: 37.06 mpg (US)
- LostCause
I would be more concerned with cracking the block. If 123 mounted a larger oil cooler, or some other less radical modification it would be nearly maintenance free, whereas a water sprayer would have to be filled up. I'm not bashing the idea, I just think simple is probably better in this situation.
American by right
Ecomodder by choice
Hypermiler by necessity
Old 05-01-2008, 12:48 PM   #23 (permalink)
123
Wow I have been so busy lately I have not checked this in a while. Thanks for everyones input. The one thing with this car is it looks way better in the pictures then it does in real life pics hide all the body work to be done. Yet it is still in good shape for its age. One thought I had was to put a water cooled engine in it that way you get better gas mileage and cooling is not a problem.
looked into Honda engines but they don't work.
Old 05-01-2008, 12:58 PM   #24 (permalink)
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Toyota Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Toyota Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
Why wont a honda engine work?
Old 05-01-2008, 01:22 PM   #25 (permalink)
123
Older Honda engines rotate the wrong way.
Old 01-18-2009, 12:46 PM   #26 (permalink)
Philthy
craggin' wagon - '01 Subaru Outback
a subaru engine would prosably work. it's the same basic configuration so it fits old VW layouts. its a common swap on VW busses
Old 01-19-2009, 12:38 PM   #27 (permalink)
Hello,
Here are the pictures:
http://img199.imagevenue.com/aAfkjfp..._122_467lo.jpg
Home Brew Challenge for Electric Geniuses (make a DIY electric motor controller) WaxyChicken Off-Topic Tech 42 08-19-2008 01:05 AM
News: Maryland legislators may require cars to make some noise MetroMPG Fossil Fuel Free 9 02-22-2008 08:51 AM
How expensive would gas need to be for you to make a 20% reduction in use? SVOboy General Efficiency Discussion 9 01-06-2008 08:29 AM
What would it take to make cycling popular igo Alternative Transportation 16 12-18-2007 01:17 PM
DIY: Make a PVC Catch Can for your PCV System TomO DIY / How-to 0 11-14-2007 03:30 PM
