Old 11-05-2011, 11:55 PM   #11 (permalink)
HyperMileQC's Avatar
Trollinsight (Retired) - '00 Honda Insight
Gen-1 Insights
90 day: 68.06 mpg (US)
Redsight - '01 Honda Insight
Gen-1 Insights
Carole - '05 Toyota Corolla Xrs
Brise-Fer - '05 Toyota Echo
Send a message via MSN to HyperMileQC
Working on the Echo-Troll today and it is going well! We will mod all winter cause we have a heated place to work.
Old 11-06-2011, 01:03 PM   #12 (permalink)
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 49.05 mpg (US)
Did you get the block heater from Toyota ?
Old 11-06-2011, 02:04 PM   #13 (permalink)
40-60-40 MPH P&G
echo-francis's Avatar
Echo-P&G - '05 Toyota Echo base
90 day: 82.76 mpg (US)
I bought the Block Heater at Pièce d'auto Jarry in Laval.
The Block Heater not installed :
Old 11-07-2011, 02:39 AM   #14 (permalink)
CigaR007's Avatar
How much did it cost, if you don't mind me asking ? Does it come with the install instructions too ?
Merci !
Old 11-07-2011, 09:33 AM   #15 (permalink)
40-60-40 MPH P&G
Merci !
it cost about 50$ and yes it come with the instruction but the instruction was really complicated even my mecanic guy have to call toyota to find the way to install it. the image is a exemple, the block heater is the same but not the rest.
Old 11-09-2011, 06:28 PM   #16 (permalink)
CigaR007's Avatar
On peut toujours parler en français, mais je crois que ça serait mieux qu'on continue en anglais afin de faciliter la discussion avec les autres membres.
Old 11-29-2011, 04:31 PM   #17 (permalink)
CigaR007's Avatar
Originally Posted by echo-francis View Post
Wheel Covers (Pizza Pans) DIY Fabrication :
Decided to put smooth wheel covers (pizza pan).
It was pretty simple, I bought some pizza pans and I nailed the cover on the original wheel cap. Took me 3 hours to make.
Here are some picture of the wheel covers :
Bought myself a set of pizza trays and I was wondering how you attached them onto the hubcap. Thanks !
Old 11-29-2011, 05:28 PM   #18 (permalink)
Gen-1 Insights
Gen-1 Insights
Good to know that you have decided to put some wheel covers on your echo!
It was pretty simple. We drilled 3 holes in the original hub cap, and in the pizza pan. Then we nailed it together with nut and screw. Did the same for the 4 wheels.
I don't know if you can see in the photo, but the nails are placed at the extremity of the cover. FYI : If you plan to put some Wheel skirts, make sure that the pizza pan do not take to much place, every inch is very important for good AF.
Old 11-29-2011, 05:41 PM   #19 (permalink)
CigaR007's Avatar
I just don't understand how the nail holds the pizza pan onto the hubcap. From what I can see in the pictures, it looks like a rivet.
Reason I ask is because I was thinking on using "pop rivets".
Old 11-29-2011, 08:22 PM   #20 (permalink)
40-60-40 MPH P&G
i use screw and nut to keep them attached
alt delete, belly pan, electric water pump, grill block, hypermiler, modding, toyota echo
