Old 02-06-2013, 09:35 PM   #161 (permalink)
40-60-40 MPH P&G
echo-francis's Avatar
Echo-P&G - '05 Toyota Echo base
90 day: 82.76 mpg (US)
i think my tank will be about 50mpg because of the cold weather (about -15c average) and the fact that my engine never gets to operating temps and learning the lights is harder then I thought
Best Tank (1557.2 Km): 2.57 LHK (91.63 MPG (US) )
Best Highway Trip (~36.8 Km): 2.16 LHK (109 MPG (US) )
Best Commute Trip avg (73.8 Km ): 2.33 LHK (101 MPG (US) )
Echo-Troll Modding Thread
I know i dont have a very good write-up
no lean-burn? no good gear ratio? p&g is the answer
MPG=1 TIME=0
Old 02-12-2013, 11:36 AM   #162 (permalink)
40-60-40 MPH P&G
the cold weather and the snow are really affecting my tank i have (again) to drop my estimation) i think i will do 40 mpg. ( driving in the snow means no p&g and no p&g means no mpg )
MPG=1 TIME=0
Old 02-13-2013, 03:29 PM   #163 (permalink)
40-60-40 MPH P&G
more hood gap seal today
MPG=1 TIME=0
Old 02-13-2013, 10:12 PM   #164 (permalink)
HyperMileQC's Avatar
Trollinsight (Retired) - '00 Honda Insight
Gen-1 Insights
90 day: 68.06 mpg (US)
Redsight - '01 Honda Insight
Gen-1 Insights
Carole - '05 Toyota Corolla Xrs
Brise-Fer - '05 Toyota Echo
Send a message via MSN to HyperMileQC
Nice job the on the insulation, is it weatherstripping tape?
Trollinsight Modding Thread
2000 Honda Insight MT Silverstone Metallic #95 (CAN) 131K mi. 81.7 Lmpg
Best Tank : 100.06 MPG (US) | 120.2 MPG (Imp) | 2.35 L/100Km | 42.54 Km/L
Best commute : 130.8 MPG (US) | 157.1 MPG (Imp) | 1.8 L/100Km | 54.84 Km/L
Best Trip : 111.8 MPG (US) | 134.3 MPG (Imp) | 2.1 L/100Km | 47.53 Km/L
Old 02-15-2013, 11:44 PM   #165 (permalink)
40-60-40 MPH P&G
yes
MPG=1 TIME=0
Old 02-16-2013, 08:45 AM   #166 (permalink)
Great work.
Do you use the alternator for the short commutes? I doubt the ROI is there, but, a Lion battery pack would be neat to replace that tired old battery.
I really like the electric WP. I think it will eventually be the way it is done with all cars.
Does anyone have any power consumption numbers on mechanical vs electric WP? I would think there is a pretty fair difference at 2500 rpm.
One other question. Do you ever bike commute when the weather is better? Ecomodding a car is great...for when you need a car. But driving a car 6 miles in nice weather to class and back really is kind of dumb.
Old 02-16-2013, 06:18 PM   #167 (permalink)
40-60-40 MPH P&G
Originally Posted by pete c View Post
Great work.
hi pete c
my battery died recently and I just buy a normal battery but I plan on buying a deep cycle battery (li-ion or normal) to replace my alt on short trip
the max power consumption of my EWP is 7.5a but when my engine is cold it run on/off cycles on 7.5a but 6volt. and recently i put 4 diodes on a switch to make it run on -2volt when i want
right now bike is impossible but when the warm weather will arrive I will study the possibility
MPG=1 TIME=0
Old 02-19-2013, 02:26 PM   #168 (permalink)
40-60-40 MPH P&G
last night i did a half alt delete. what I did is: I buy a small battery charger and remove my serpentine belt. I charge the battery at night . to test my battery range I just put my headlight on for 45 min and my battery drop from 12.4v-12.5v to 12v12.1v about .4v and I know that my commute take 20 min each way and my headlights takes more energy per minute then my commute because i p&g
i just drive to the bank this morning and i immediately feel more power in my acceleration
the bad side is that my cold start idle are a bit higher then before and I was already complaining about that
MPG=1 TIME=0
The Following User Says Thank You to echo-francis For This Useful Post:
paulgato (11-04-2013)
Old 02-21-2013, 08:43 PM   #169 (permalink)
Gen-1 Insights
Gen-1 Insights
I would really like to drive the Mazda without any belt, but having a mechanical WP, this is impossible and stupid .
Old 02-24-2013, 12:17 AM   #170 (permalink)
40-60-40 MPH P&G
yesterday I went to a DIY garage to change my transmission oil. I replaced dyno juice by this:
you can see the removed frontal belly pan in this picture
here is the part without belly pan
MPG=1 TIME=0
alt delete, belly pan, electric water pump, grill block, hypermiler, modding, toyota echo
