Old 10-12-2018, 12:48 PM   #1 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Lightbulb Effects of speed, wheels, temp on EV range
As illustrated by Renault
Scroll down to "Simuleer uw rijbereik" to play around with speed, temperature, wheel size and see how it affects range.
https://nl.renault.be/voertuigen/ele...agens/zoe.html
Pour les francophones :
https://fr.renault.be/vehicules/vehi...iques/zoe.html
Old 10-12-2018, 01:07 PM   #2 (permalink)
It sucks.
I'm pretty sure below 45F I won't be able to make it to the big chain hardware store and back with my leaf and trailer with out stopping to charge.
Old 10-12-2018, 03:24 PM   #3 (permalink)
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
It sucks.
Home depot and Rona have regular 120V 15A receptacles on their parking lot lights up here. The Coop found parking lot lights that don't have the courtesy receptacles
Maybe you'll have to browse for a bit longer to let the Leaf get enough charge?
In THEORY there is no difference between Theory and Practice
In PRACTICE there IS!
Old 10-12-2018, 07:15 PM   #4 (permalink)
With 120v power I would pick up around 1 mile per 15 to 20 minutes of charge in winter.
But I would need it.
Old 10-15-2018, 05:58 PM   #5 (permalink)
This flirting with freezing temperatures has nearly cut my range by around 20%.
If I use the heater, even more.
Old 10-15-2018, 06:10 PM   #6 (permalink)
Mazda CX-5 - '17 Mazda CX-5 Touring
90 day: 26.68 mpg (US)
Can you preheat on grid power to improve range?
If you plan your trips carefully, you can set the car to finish charging just before you depart to give you the longest range and warmest battery.
I used to set my Prius to finish charging just prior to departing. It had the ability to either begin charging at a set time, or to set the end of charging time and it would adjust when it began based on the end time.
Using the HVAC heater will drastically reduce range. Seat/steering wheel heaters take hardly any power at all.
Old 10-15-2018, 06:14 PM   #7 (permalink)
I can clean, rearrange and relocate items in my garage and put the leaf in there with my coal furnace and do what I have always done with gas and diesel vehicles where I put a little electric space heater in the car and run it for a bit before driving.
I started doing this in 1998 when I moved to maine.
Old 10-18-2018, 07:53 PM   #8 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
It helps. I preheat my Spark in the winter
I still have to run the electric resistance heater on defrost to keep the windshield free of fog. Our humid / rainy winters in Portland mandate the use of the heater instead of just using the heated seats and a jacket. In the winter defrosting the windshield consumes about 1/3 of my battery pack during my 50 mile / 90 minute commute (roundtrip)
I wish GM had installed a heat pump instead of the 5 kW resistance heater.
Old 10-19-2018, 09:47 AM   #9 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
Looks like during cold weather I lose a minimum of 10% and a maximum of 25% range. But I use the least heat I can tolerate, i MUST use the defrost or the windshield fogs very badly.
Old 10-19-2018, 10:12 AM   #10 (permalink)
I don't think im losing range but I do get horrendous sag when its below 70f. Enough to trip the low battery systems. I do prewarm the cab and batteries from house power.
