07-03-2013, 11:07 PM
#41 (permalink)
halos.com
746 watts is 1 hp, right? 500 watts may not seem like much, but if you don't have to generate it over a 400 mile trip, then the savings should start stacking up.
justme, if auto parts stores do sell the clutches separately, that'd be good to know. I've always been told I couldn't get one separately. Although, I may not have as much use now since I installed the underdrive pulley.
07-05-2013, 01:56 PM
#42 (permalink)
I thought I remember hearing that normal cruising typically consumed only 7-8 HP. (Obviously, steady-state conditions, and probably referencing a sedan.)
So saving 1/2 HP could be a large percentage.
Anders
07-05-2013, 02:35 PM
#43 (permalink)
A smaller engine car that spins its P/S up to 3k to 4k could be sending well over 1hp to the P/S pump.
Those small cars that spin 3-4k tend to only needs 10 to 15 horsepower to over come drag and rolling resistance and maintain speed. Removing a 1hp load off the engine could be pretty big, to a smaller car.
07-05-2013, 03:01 PM
#44 (permalink)
Just saw a story about the Ram, says electric steering saves 5 hp.
07-18-2013, 07:18 AM
#45 (permalink)
ECOModder
RAV - '13 Toyota RAV4 XLE AWD 90 day: 27.56 mpg (US)
Awesome work.
I rarely comment on here anymore, but when I read this post via the newsletter, I had to. Awesome work! Very ingenious!
3585 pounds of twisted steel.
Recreational | Active | Vehicle | 4x4
...scratch that... AWD
07-20-2013, 09:40 PM
#46 (permalink)
What are your gains with the underdrive pulleys, are they the Lightweight?
07-23-2013, 11:38 AM
#47 (permalink)
What happens if you're cruising down the highway and have to swerve?
07-23-2013, 11:47 AM
#48 (permalink)
Turn the steering wheel.
07-23-2013, 11:57 AM
#49 (permalink)
Good luck performing a swerve and recover manouver at speed w/o PS.
07-23-2013, 01:33 PM
#50 (permalink)
Why? I've had my power steering pump disabled for quite some time and the only time I really notice the lack of assist is when the car is stationary. How about you? Have you tried it?
