Old 07-24-2013, 10:24 PM   #51 (permalink)
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
Originally Posted by tony_2018 View Post
What are your gains with the underdrive pulleys, are they the Lightweight?
Unfortunately, the wind won't stop blowing long enough so I can get the truck out for some testing. So, I can't give you any data. I can tell it freed up some HP. AIRRAM's website says the underdrive is worth 7-8 hp, if I remember correctly. Yes, it is 3 pounds lighter than the OEM pulley. I weighed them both.
[edit] I've driven my truck without the belt turning the power steering pump. Above about 20 mph you can't tell the difference...
Old 07-26-2013, 01:57 AM   #52 (permalink)
Originally Posted by oldtamiyaphile View Post
What happens if you're cruising down the highway and have to swerve?
Turn the wheel, at highway speed there is surprisingly little difference between P/S and no P/S.
With no P/S you are less likely to over correct.
I take it you never tried driving something with no P/S.
Old 07-26-2013, 08:06 PM   #53 (permalink)
halos.com
Originally Posted by justme1969 View Post
This must be another new thing as I worked at auto stupid back in 97 and 98 and they did sell them then. I will explore this a little.
Mabe just a sorry sales person, I also get them most of the time.
Look for an auto stupid in amongst or near dealerships, that is going to be a supplier yes your genuine GM ends up being guess who lots of times?
I just checked on Ebay, searched for ac compressor clutch...and it seems you can buy one now! New AC Compressor Clutch Jeep Grand Cherokee 1999 2004 6CYL 6GROOVES | eBay
Hmmm, might have another project to undergo now.
(edit) Frank, which vehicle are you NOT using the power steering? On my truck it's rather difficult to turn from a stand still (not good with golfer's elbow). But if I could remove the entire ps system, that weight savings would be nice. And, I forgot, when I tried it, I left all the fluid in the system and all the hoses connected. If I'd connected the rack to itself, I think it would have been easier to steer.
Old 07-26-2013, 08:24 PM   #54 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Good luck performing a swerve and recover manouver at speed w/o PS.
This is not an issue at anything over a few MPH. I have been driving my 98 Civic DX without PS for over two years now, 30K miles. As Frank Lee and others with experience will tell you, you'll only really feel a difference at stationary or a few mph.
Old 07-26-2013, 08:39 PM   #55 (permalink)
The "Sport Coupe" Tempo.
I'm always coupling/decoupling from trailers with the F150 so the power steering is going to stay on that one. Plus I don't think it'll make a noticeable fe change on it.
Got a Tracer I'd like to hit 50mpg with; best fe was 42 so I'll have to see what it'll take to bypass the power steering on that one.
Old 07-26-2013, 10:02 PM   #56 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Yes, I take back what I said earlier. I drove many miles with a non PS 4.1 Ford and held many a slide. I was thinking about the van I just bought that hardly steers with PS and I have yet to get to the bottom of that.
I was also thinking that simply disconnecting the PS pump makes the steering heavier than if the car originally had manual steering, as the ratio is usually different, but I realise it's only 10-20%.
In fact I have a spare A/C unit with clutch
The Following User Says Thank You to oldtamiyaphile For This Useful Post:
Diefuelur (07-27-2013)
Old 07-28-2013, 05:36 PM   #57 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
having driven with a "broken" PS system for 9 months or more, at any speeds over 15 MPH its hard to tell its not there. at low speeds it just takes more effort to turn the wheel.
Old 07-29-2013, 08:21 AM   #58 (permalink)
justme1969's Avatar
OK I dont really have the time to research it properly but there are some options I think I would go to a upull it myself, just so that I could match shaft size to clutch because from limited memory we stocked 11 diff clutch assy. back then.
12V Auto Air Conditioning Clutch For TOYOTA Coaster (AC.106.002)
Santech/Clutch hub for Denso 10PA (MT2302) | A/C Clutch and Parts | AutoZone.com
I have not tried JC whitney either but NAPA showed one in first 10 pages for old school dodge.
If I could only recall the name of the company????
Sorry folks thats my best ten minutes without including e-bay or similar searches.
Also that NAPA unit was a first 10 pages search probbably more in there.
Old 07-29-2013, 09:58 AM   #59 (permalink)
For a large vehicle like a full size pickup or big SUV I calculated that it will only offer about a 1/2mpg improvement on the highway.
If you can do it (delete or clutch the P/S) for under $100 it could be worth it.
Old 07-29-2013, 11:34 AM   #60 (permalink)
justme1969's Avatar
It would be awesome for a throttle sensitive switch mabe disconnect @ 1800 rpm? Not sure application is key but a toggle switch to flip on when parking would be Jazzy for my app.
But the undieing POS KIA needs none, I cant even remember what that car felt like with it now. Also for the others it has no issue about control steering or panic motions its rack n pinion unit probbably does better in those applications without due to true feeling for response.
diy, electric clutch, electric pulley, power steering
Power Steering delete for fuel economy gain - anyone done it? bennelson EcoModding Central 92 01-27-2017 03:58 PM
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1041 07-28-2014 09:19 AM
Can I use a GENERATOR to power an Electric car directly? Nerys Fossil Fuel Free 128 10-01-2012 01:24 AM
Ontario suspends registrations of converted electric vehicles (update: ban lifted) MetroMPG Fossil Fuel Free 45 09-25-2010 05:21 PM
My wife doesn't mind not having power steering in the tank!!!!! IsaacCarlson Success Stories 21 10-19-2009 11:50 AM
