Old 10-14-2019, 09:00 PM   #41 (permalink)
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
Maybe I missed it, but there was no talk of a gas with gas pusher was there? If you use a small gas engine with enough power to maintain speed on a flat road it should work right? Main engine off (or maybe idle if auto) with small one propelling the car.
What do you guys think?
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
Old 10-14-2019, 10:22 PM   #42 (permalink)
Originally Posted by ai4kk View Post
How about modifying an older 4WD car, say a Subaru Impreza with electric motors on the rear wheels only or maybe even a standard FWD car with a rear drive axle incorporated in from something small, like an old Toyota or Datsun or small traction motors directly at the wheels themselves. This way, the electric motor/generator could be tied into the rear wheels while keeping the gasoline motor for the front? One could either manually control the power split or devise a simple controller, perhaps via laptop that could read various parameters and issue the appropriate commands or some combination of the two.
That's roughly what Volvo is doing to its entire PHEV range, and Toyota does with 4WD versions of its hybrid SUVs, even though they also retain a regular hybrid setup on the front-end (with Toyota retaining the HSD, while Volvo resorts to a "pancake" motor between the engine and transmission) and just supplement it with the rear motor.
DIY: plastic rear wheel skirts (Geo Metro) MetroMPG DIY / How-to 57 06-12-2014 09:16 AM
DIY Rubber Front Wheel Skirts newtonsfirstlaw DIY / How-to 32 05-19-2011 07:45 AM
Done: A-B-A test on rear wheel skirts - Corolla, Camry Hybrid MetroMPG Aerodynamics 11 06-06-2009 03:49 PM
Home Brew Challenge for Electric Geniuses (make a DIY electric motor controller) WaxyChicken Off-Topic Tech 42 08-19-2008 01:05 AM
DIY Chevy Avalanche conversion to parallel hybrid MetroMPG Hybrids 2 12-01-2007 10:00 PM
