Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 08-02-2012, 03:59 AM   #31 (permalink)
clank - '99 jeep tj sport
90 day: 17.32 mpg (US)
Originally Posted by some_other_dave View Post
That was the one I was speaking of earlier. Tested and debunked.
by who; most of what i've read on the web leads to mixed results
E-Ram Electric Supercharger Testing
this guy thinks it produces additional power. Not much and it's still in the realm of error for both dyno and operators.
t vago's page suggests that it's about as useful as a cold air intake or larger/different throttle body.
ps. if you don't test something more than once; the subject of error over takes what might be good data. case in point the fuel logs
Old 08-02-2012, 05:46 PM   #32 (permalink)
Sorry, I don't have the information any more. I found a link to it through one of the CRX-related BBSes, either the crxresource one or the crxcommunity one. This was quite a few years ago, though.
-soD
Old 08-02-2012, 05:57 PM   #33 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Hey, if you want to spend $300 to get a shiny new bilge fan, and test it over and over and over and over and over again, be my guest.
Old 08-02-2012, 09:32 PM   #34 (permalink)
NightKnight
NachtRitter's Avatar
RippinRoo - '05 Subaru Legacy Wagon 2.5 GT
Subaru
90 day: 21.16 mpg (US)
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 53.91 mpg (US)
Olga - '03 Volkswagen Jetta Wagon
90 day: 46.24 mpg (US)
Post results when you do!
Old 08-02-2012, 09:59 PM   #35 (permalink)
Originally Posted by baldlobo View Post
yes it does, force= mass * velocity
mr. knights device was powered by 1 or 2 extra batteries required to power the 3 starter motors; and i think in the end the car was hauling around 200lbs more then it would have with a normal m62 or m90, completely making 5-6lbs of boost, negated by the additional weight.
ps. 15hp=12kW
As said, F=MA. 10,000 rpm free-spinning is not quite the same as 10,000 rpm under load. A regular turbocharger will be spinning at 60-80,000 rpm under load... accelerating... shovelling air into the engine.
I have no doubt that 7 kW of motor is enough to net some positive pressure, but again, I doubt you'll get more than 5-6 psi on your 4 liter motor... looking back... maybe just 4-5 psi. Would be an interesting project... attach it to a supercharger... see how much boost it makes compared to hooking the same charger up to the belts, and how much power that boost will make.
Old 09-06-2012, 03:56 PM   #36 (permalink)
90 day: 31.19 mpg (US)
I remember the e-charger! Bilge pumps, too! I used to search for stuff for my Prelude and I laughed at everything but OEM parts. I do not know about now, but the e-charger said that it removed 0.5 PSI of vacuum losses (or something) and provided the same amount of actual boost.
I remember someone doing the math of how much air an engine pulls in on its own and linked the manufacturer's specifications on the bilge pumps, not the fantastically unrealistic numbers on eBay. eRacing may make a bilge pump, but at least their claim that it would not fall apart and fly into your engine sounded credible.
Okay, I am going to find that leaf blower engine.
Old 09-07-2012, 12:31 PM   #37 (permalink)
Drive less save more
ecomodded's Avatar
90 day: 60.42 mpg (US)
How bout you find a gas leaf blower, put on some wheels and a seat, steer by leaning and make a thread showing the complete build,lol.
Save gas
Old 09-08-2012, 07:44 PM   #38 (permalink)
No, what you need to do is build a special go-kart with a two-inch steel shield behind you and then drop live grenades!
Old 09-08-2012, 08:20 PM   #39 (permalink)
MPGuino Supporter
t vago's Avatar
Probably would be wise to install some sort of shock absorbing mechanism between the go-kart and the shield. One could carry a bunch of grenades in the cart, too, and have a ejecting mechanism to shoot them, one at a time, at a spot right behind the shield. Timing the grenade explosions could be tricky, though.
Old 09-08-2012, 08:24 PM   #40 (permalink)
You'd always want an SUV or pickup behind you otherwise much of the blast energy will be wasted to the rear and not propel you forward as much as you want.
